Can anyone explain how to change a movie title that was downloaded from Playon Cloud? It has the wrong title format. I clicked "correct mismatch" but it didn't work. Should I just find the movie and retype the title? Any help would be appreciated. Not sure where to post this.
What does that mean?
Pretty sure all imported movies are matched against TMDB
didn't work - What happened?
Hi, thanks for your reply. Instead of titling it "Charade (1963)," it's titled "Charade - Cary Grant, Audrey Hepburn, Uncut Suspense Classic! (1963)". And it doesn't display any cover art, just a purple square. How would I fix this so it displays properly?
Locate the Movie in Channels DVR web UI
Click Find Match and change the Title in the search box to Charade (1963), then click the match found
You could also match it to TMDB instead of Gracenote
OMG ty so much!! Worked perfectly!
And if something gets imported and is automatically mis-matched, instead of Find Match, you would select Fix Incorrect Match
Thanks, now I'll know what to do if this happens again! I spent a couple of hours trying to find the answer in the documentation and troubleshooting but no luck--you've been so helpful.
