Hi there,
What is the most simple way to get the cool beta on my FireTV 4k stick?
I have signed up for the beta program for android.
Hi there,
Might not be possible. The Channels devs don't do Beta on FTV any more. The Beta system was too wonky. Gave them too much grief. I'm afraid you may have to wait for the stable release.
You can sign up for the beta through the Play store. Unfortunately, then you have to find a way to download the apk of the beta onto your computer so you can use adb or similar to side load it.
I used APPS2FIRE .
APP2FIRE. Use an android device on the same network and you can upload the APK from your device to the fire tv.
