Every time I start playing a recording, the captions come on. I checked my TV setting (Sony) and they are turned off. I'll turn them off while watching, but as soon as I start another show, or even if I just exit the show to go to the guide or wherever, they start up again. On version 106.7.1936.
Please submit diagnostics after this happens
submitted.
How are you turning the captions off?
The TV remote has a CC button that turns them off or on. You asking that, I went and turned them off from the menu and they didn't come back on when I restarted the show. Maybe that was the issue?
Yea that seems to be the bug. I have fixed it for the next build.
