From my HDHomerun dashboard, I have red X'd out channels I don't want to appear at all in my pull down "quick" channel menu, but it only seems to reflect the deleted channels on some of my streaming devices, but not all.... it's hit and miss. How do I make sure that each client knows not to show X'd out channels?
Check out Channel Collections. You can organize your own sets of channels and they’ll sync across all your devices.
Thank for the tip re:Channel Collections. It's not much different for me, as I really only need one set of "favorite" channels... but, at your suggestion, I did set a Collection up to duplicate my existing favorites, minus one channel, as a test. However, this does not seem to address my question about how to get the limited set of channels in Collections, to appear in the pull down Quick Guide, which still displays ALL Channels, regardless of which "filter" I have selected to the left of the main grid guide. At one time, I had the Quick Guide showing only the channels that were in my selected filter, specifically, Favorites. That, however, is no longer the case.... even using Collections..... The QuickGuide still shows ALL AVAILABLE Channels..... which is annoying. Thanks though!
Channels app > Settings > General > Live TV > All Channels Collection > Off
You can set this via the server for all clients too:
Fofer, your tip led me in a productive direction, thank you! There is an option there where you can pick which Collection appears in the Quick Guide! Bingo!
