New user here, so this question might be trivial. I changed guide source for one of my sources and I can't get any guide data to load. I would like restore the original Channels guide (grace note?) but I see no way to do that.
In the Guide Data section within settings I only have options for Redownload or Change Provider. Change Provider only gives me choices for some other guides I have tried (unsuccessfully) base on a zip code search.
I imagine I'm overlooking something obvious. Thanks for any help.
