Hulu Live TVE authentication is failing
The same problem I reported about 3 weeks ago happened again. Tried a rescan of all channels, and then removed the Hulu Live source and tried adding it back. The only listings under Manage Devices for Hulu is the browser I logged into to check the devices and an Android TV login for the Hulu app. The Hulu Live login under channels is showing the cable provider authentication failed message. I've got version 2023.01.31.0414 version. Any ideas as to what I need to do?
If you've already followed the instructions from this thread, then it would appear that you need to submit diagnostics as suggested here in such a friendly manner;
That doesn't make sense. I'm having this same problem but the tve isn't in the list of devices to manage because it can't login. What is the logic in removing something from allowed devices to fix this problem?
I’m having the same issue. Nothing to remove in devices and cannot authenticate but logging in works just fine.
