I keep getting error: The connection to the tuner was lost. Press play to try again
I noticed it more when watching ESPN cause I'm attempting to watch the playoff games
Have you submitted diagnostics from the app after you have this happen?
Yes i did a few days ago but not recently
And it plays the exact samw thing every time I turn to ESPN on multiple TVs
The last diagnostics I see from you are from April 1st. Could you submit again from the app and also submit from the DVR?
just sent one again...so frustrating that I can't user ESPN at all....its is doing this on EVERY tv
any idea how I can get espn back?
Are you able to change your DNS server to the DNS servers provided by your ISP?
If you download PingPlotter and then have it ping content-ausw2-ur-dtci2.uplynk.com over a period of time, what does the graph look like?
i updated everything and it seems to be working today...I am going to change the DNS servers today cause that seems to be the only error in diagnostics
now my tuner isn't even being found and I am getting the connection to tuner lost again
The latest diagnostics I see are reporting from Fubo that the login or password is incorrect. I have just started a new pre-release build that will improve the error messages being reported for that.
If you are having additional problems, if you go into the DVR web interface and scan a single channel that you are having problems with and then submit diagnostics again, we can check those out.
how do you scan a single channel?
Sources -> Manage -> Rescan Channels and then click the Gear next to a channel and select Rescan.
oh ok...
Im getting the same message on all of my tv everywhere channels, my hdhomerun channels work but nothing else
