Ideal Set Up - Configuration Xfinity CableCARD X2 HDHR3-CC
What determines 'uptime' in the 'Server/status' block of the settings page? I believe I've been up for likely 18 - 20 days.
2024-07-11 13.48.59 192.168.132.78 48e095c9b467
How long the server has been running. Since you updated to pre-release on 5/7 it's been running since then at the latest.
Thank you! Hmm, I didn't realize I did that. I thought I actually tried to avoid anything other than 'stable'.
Stable releases are done automatically ... prereleases are done by you.
Your uptime is 2 days. This means your dvr machine restarted or the software was updated 2 days ago. Obviously the last software update was May 7th so this means the machine you run the dvr on was rebooted 2 days ago. Uptime is the last time the software runs the start process.
At 30 days my W11 T570 ThinkPad has quit. I've no idea what is up with that BUT I had added an 8G RAM Memory to my DS220+, ran a memory test, it passed and summary shows now 10G Memory. I've gotten it set up I believe correctly and it's been running most of today and functioning.
With my ThinkPad I had a 3TB External drive for the server. Is there an easy way to get the recordings from there to my DS220+ or maybe can I connect it to another PC and use it in some way as a source to view those recordings? There's nothing that I actually need but thought about.
