If I upgrade to HDHomeRun Quatro
How does Channels handle the change? Can I just unplug the old one (the Connect) and plug in the new one (the Quatro) or is there a step by step process I need to follow?
Thanks
You will need to add it to your DVR, by logging into the DVR web settings page on your NAS and assigning the guide data to the new tuner by entering your zipcode. Everything else will work automatically including any existing passes and upcoming recordings.
Thanks. I had wondered myself as I’m going to buy a Quattro once they are available.
Thanks so much.
Not sure if it’s where you are located but the Quattro have been out a while.
The QUATRO is only available in the US. It should be launching internationally in the next few months.
