Images cut off in Favourites Guide drop-down
Frequently, one or two of the program images in the Favourites Guide will be cut off on the sides. It appears that the software has incorrectly assumed that the image should be profile when it is in fact landscape.
Here is one example:
As you will notice, the smaller image in the playback area below is not cut off and it displays correctly.
And here is another example where the fallback image has been cut off on the sides:
This happens when a channel is playing a movie. Will fix.
Great, thanks for taking a look.
Who is your EPG provider set to? On the Settings tab does it show a SiliconDust logo or Gracenote
The Settings tab currently shows the SiliconDust logo.
Is it possible to change the EPG provider using the app?
I’ve fixed this issue for the next version.
SiliconDust guide data is the best quality and used by default whenever available.
