Important Beta Test for Apple TV DVR Connectivity
There’s been some serious issues recently with discovery and connectivity with Channels and Channels DVR recently.
To address it, we’ve rewritten the way that Channels boots up and discovers Channels DVR. It’s been reworked so that it should even be faster since it attempts to connect to the last IP address it saw Channels DVR at right away before resorting to bonjour discovery.
This change has affected not just local discovery but also the way Remote DVR works when attempting to connect to your Channels DVR server while away from home.
It’s very important that we get as many people trying this new version and living on it for a little bit before we send it out to all of Channels’ fans.
If you are part of the beta, could you please pull down and install the beta from Testflight and use it for a couple of days inside your home, and if possible, when using Remote DVR.
Thanks everyone!!
So far it looks like the beta version can log in remotely with no issues (I used to have to log out + reconnect when my server updated the IP or randomly after a few days) It also looks like connecting is a snappier process
Are there no longer active beta builds for tvOS or iOS? I was testing both of them but they seem to have expired or I have been removed from testing.
We're in the middle of revamping the beta program. You'll hear more about it this week.
Don't worry, you're not missing anything right now anyways. We haven't pushed any new betas in a while.
We've announced our new beta program. You can read about it here: https://getchannels.com/beta/
#SignedUp
Same here. The new process was simple and straightforward.
