Working now with the latest release.
iOS and tvOS beta build Version 2019 (11.19.2025) has been posted:
- FIXED: Crash that can happen on tvOS during startup
Have you seen this happen more than once? I haven’t been able to reproduce this issue. If it does happen again can you send a diagnostic report?
I installed the beta earlier on a few devices that use a remote dvr and a local dual tuner (for live tv only). If the non-beta app was still installed it would bring up the login page, but if the non-beta app was deleted before installing the beta app it would only show a loading animation indefinitely. This behavior persisted after a force close and a full reboot.
@JMcGuire: When you see the app hang would you mind grabbing the logs from http://<apple-tv-ip>:57000/log and emailing them to [email protected]? I'd like to figure out what's going on here.
Log sent, let me know if you need anything else
I was able to figure out what the issue is and I'll be releasing a new build tomorrow. Thank you for reporting this issue.
iOS and tvOS beta build Version 2019 (11.20.815) has been posted:
- FIXED: Hang during app startup after clean app install
iOS and tvOS beta build Version 2019 (11.21.31) has been posted:
- IMPROVED: Prioritizes IPs over hostnames for discovered DVRs
- FIXED: Crash while starting to watch Live TV via DVR if the DVR hostname cannot be resolved
iOS and tvOS beta build Version 2019 (11.21.1802) has been posted:
- FIXED: Up Next is updated after marking an episode as watched
iOS and tvOS beta build Version 2019 (11.22.19) has been posted:
- FIXED: Properly detect legacy HDHomeRun devices when connected to a DVR
Is top row on the tvOS betas working for anyone else? Mine haven’t in a while with these new numerous updates.
Does not work here either. I haven’t noticed since I normally do not keep the beta on top row.
I’ll check it out. Thanks for reporting it.
@AeroR1: @d21mike: I've released a new version that fixes the Top Shelf issue. Let me know if you have any more issues.
iOS and tvOS beta build Version 2019 (11.24.224) has been posted:
- FIXED: Ensure Top Shelf updates properly on tvOS
That was a quick fix. Works good here.
iOS and tvOS beta build Version 2019 (11.24.356) has been posted:
- FIXED: Fix situation where some data was not refreshed on app relaunch
iOS and tvOS beta build Version 2019 (11.24.2245) has been posted:
- IMPROVED: Check for added and removed channels on every app launch
iOS and tvOS beta build Version 2019 (11.25.654) has been posted:
- FIXED: Ensure the correct tab is selected when reconnecting after DVR Not Found screen is shown
Thanks to everyone who helped with testing this! It’s been very helpful for finding bugs.
The changes have been release to the App Store.
