We've just released a new iOS and tvOS beta Version 2019 (11.19.326) that greatly improves how discovery works for the DVR and HDHomeRun. It's been a two month project to get it to completion and I've been very happy with how it's turned out.
The Highlights
- The app handles moving from WiFi to Cellular or from one WiFi network to another better
- The app spends less time validating the connection when it is coming back from the background
The end result is that you should see less confusing error messages and flipping between Channels and other apps should be much faster.
The Details
There have been a number of frustrating issues that have been reported that have been addressed including:
- Bogus "Tuner Not Found" errors after opening the app
- Not all HDHomeRun tuners are listed when they should be
- Guide was sometimes blank and not showing the current shows
- "Welcome to Channels DVR" screen being displayed when it shouldn't when trying to connect remotely
- "Search Again" button on the "Welcome to Channels DVR" would not try to connect to a remote DVR again
- Sometimes the client would not notice if you had moved from your home network to another WiFi network
Additionally, some nice improvements have been made:
- If no devices were found, a search is done in the background to keep trying to find them
- When opening the app after it has been in the background, a much shorter health check is done
What Could Go Wrong?
This is a revamp of the entire system that looks for DVR and HDHomeRun devices on the network, so there's always a chance strange bugs and inconsistencies could crop up.
If you see error messages that you don't expect, or can't connect to devices that you think you should, please let us know here. When you see an issue if you can "Submit Diagnostic Logs" I would appreciate it. It will help me identify what's gone wrong and how to fix it.
Known Issues
- None
Updates
iOS and tvOS beta build Version 2019 (11.25.654) has been posted:
- FIXED: Ensure the correct tab is selected when reconnecting after DVR Not Found screen is shown
iOS and tvOS beta build Version 2019 (11.24.2245) has been posted:
- IMPROVED: Check for added and removed channels on every app launch
iOS and tvOS beta build Version 2019 (11.24.356) has been posted:
- FIXED: Fix situation where some data was not refreshed on app relaunch
iOS and tvOS beta build Version 2019 (11.24.224) has been posted:
- FIXED: Ensure Top Shelf updates properly on tvOS
iOS and tvOS beta build Version 2019 (11.22.19) has been posted:
- FIXED: Properly detect legacy HDHomeRun devices when connected to a DVR
iOS and tvOS beta build Version 2019 (11.21.1802) has been posted:
- FIXED: Up Next is updated after marking an episode as watched
iOS and tvOS beta build Version 2019 (11.21.31) has been posted:
- IMPROVED: Prioritizes IPs over hostnames for discovered DVRs
- FIXED: Crash while starting to watch Live TV via DVR if the DVR hostname cannot be resolved
iOS and tvOS beta build Version 2019 (11.20.815) has been posted:
- FIXED: Hang during app startup after clean app install
iOS and tvOS beta build Version 2019 (11.19.2025) has been posted:
- FIXED: Crash that can happen on tvOS during startup
- IMPROVED: Manually entered DVRs are now prioritized over discovered ones
iOS and tvOS beta build Version 2019 (11.19.1836) has been posted:
FIXED: Intermittent crash when app is reopened
