Generally, loving Channels. It’s what I wish Live Channels had been.
Not sure if it’s intended, but behavior of the left D-pad key when on a leftmost item/column is inconsistent between the Guide and On now views. In On Now, Settings and the beta DVR views, pressing the left D-pad key slides out the left main menu (not sure what that’s called in Android TV–maybe Navigation Pane or Browse Lane?) if any leftmost item is highlighted. In the Guide view, pressing left in the same situation does nothing. It is necessary to press Back to slide out the left main menu. I’d much prefer Guide behavior to be consistent with behavior in the other views.
