I had a hard drive failure and had to "upgrade" my mac mini with a fast 1TB SSD. I did my time machine full restore and most things are running properly. However, channels dvr is not starting up correctly. I am getting.
.2020/02/15 05:50:50 [SYS] Starting Channels DVR v2019.12.05.0128 (darwin-x86_64 pid:1948) in /Users/gregoryulsh/Library/Application Support/ChannelsDVR/data
2020/02/15 05:50:51 [HDR] Found 2 devices
2020/02/15 05:50:58 [SYS] Started HTTP Server
2020/02/15 05:51:01 unable to load snapshot, failed to load segment: error opening bolt segment: open USA-MN22415-X.airings/store/00000000a2d9.zap: no such file or directory, continuing
2020/02/15 05:51:01 error parsing mapping JSON: unexpected end of JSON input
I had some renaming of internal/external hard drive names that might have this zap file no longer the same location or is gone.
Any ideas on next steps?
