Instructions for remote access?
I have ordered a Synology DS220+, HDHR, and a CableCARD from Comcast for my Channels setup. My goal is to be able to record and stream both within the home and remotely from a second home.
Do I need to do any special network configuration to expose the DS220+ for remote Channels access? If so, I’d love instructions for how to set this up. I have a Comcast router (needed for my home security system, unfortunately), and plugged into the Ethernet port of this is a Google Nest WiFi router that my whole home network (both wired and wireless) is connected to.
Have you read through the support article?
After reading through that, then post back with any additional questions.
Awesome. Seems straightforward except for the fact that I basically have 2 layers of routers. I don’t know that it will “just work”.
Anyone have a setup like mine?
WAN —> xfinity router —> nest wifi router —> All devices
To make it wast you can connect channels to your 1st router or disable the double nat and put your nest router in bridged mode.
As stated above, the best option is to put one of your routers into bridge mode, so there is only one router on your network.
The other option is to have 2 layers of forwarding: first you forward port 8089 from your Xfinity router to the Nest router; then you forward from the Nest router to your server.
(Edit: autocorrect made some wonky substitutions and words seemed to vanish)
I’m going to try the double forward first. Don’t know that I trust my xfinity router to keep my home network safe.
Any extra precautions you take to prevent network intrusion?
And you shouldn't. But if you can put your Xfinity router in bridge mode, then that would be the better option.
I personally use the tools of my routers. One of them runs a current release of OpenBSD, the others are a mix UniFi routers and security gateways. If you want to add additional firewalls or packet filters or other tools, that's your choice. Just remember that added complexity and non-standard setups can make troubleshooting harder when things go wonky.
Some routers also offer a DMZ option that you can setup with the IP of the second router.
Otherwise a chained port forward will work.
This is the path I had to take with a Verizon DSL router, because the bridge mode was broken and wouldn't ever work.
Ah. I’ll check for that. Thank you!
