I've been having a problem with PlayOn Home which may be due to an interaction with Channels.
I am attempting to record Netflix movies using PlayOn Home. The movies start recording, but at some random interval, PlayOn reports that the recording is finished, even though it was not.
I am left with a file on my hard disk which is incomplete and will not play at all.
My theory is that PlayOn Home is using the same folder to record into as Channels is using to check for new Personal Media, and somehow this is causing a problem. Could this be my problem?
If so, is there some way around this other then recording into a separate area and then manually moving the file after the recording is finished?
