What is your display scaling set to? Even if you have a 4k res if the scaling is too high it won't render at 1080p. The prism logs will tell you your max res allowed if it can't do 1080p.
oops this was checked via teamviewer at 3840x2160 Ill go login at the tv itself and recheck
Could the channel lineup precache also be enabled for multiple video providers like usanetwork.com? That might fix the random over 15 second timeouts on first tune for those.
So logging in at TV I set it to 720P High @ 12Mbts BUT need to reboot PC for it to stick So lesson learned The disabled items all remain disabled BUT the video out put looks much Better
Im stuck at 10 seconds to see a channel BUT other than a new high power PC ill leave it as is
You need to set your video resolution env vars to something higher than 1920x1080. Try a 2K resolution like 2560x1440.
For Windows users: pkill is not a command that native Windows recognizes, so I was not able to install the PrismCast service and as a result I always manually start it console. Is there a way to get the service running otherwise? Because Windows doesn't recognize pkill, there are frequently numerous errors in the console command window at the end of a day - are there any workarounds for this? Everything is working admirably otherwise.
I realize this wasn't specifically developed for Windows, so I'm probably grasping at straws here, but thought I'd at least ask. Thanks.
It's pointless, containerized Chrome doesn't use it, and ffmpeg (in this case) doesn't need it.
Other Unraid Docker users have reported that as well.
How you spin-up and manage your Docker containers, wasn't my point. I was just trying to let you know that other people running this project with Unraid as the host OS have reported issues. It could be a coincidence or not -- it's just an observation.
This isn’t entirely true, it varies be region.
My guess is you are west coast as their URLs do seem to line up with Gracenote ids. For example for discovery channel, your url will probably be:
https://watch.spectrum.net/livetv?tmsid=80399
That link doesn’t work for me in the Midwest.
My url for discovery is:
https://watch.spectrum.net/livetv?tmsid=56905
Can an east coaster with Spectrum try these links and see which one works? It is unknown how many regions Spectrum has, it could be just east and west but it could be 20 different regions. If there is an east coast spectrum user please PM me and we can compare some URLs as I have a pretty extensive list. If it turns out just to be two regions we could probably get something together to submit to @hjd.
I live in Florida and almost every one of the station_id I tested in the tsmid= worked. None of the Pacific stations would tune though.
I wouldn't spend any time on this. The next release of PrismCast in a few hours will have full native support for Spectrum.
Awesome to hear! I will say in the vast majority of the channels will work with the tms as Gracenote. There were a couple that were not but a user will be much further ahead to add all the spectrums lineup and fix the one or two that are bad.
This is awesome!
Now a user can tell PrismCast "these are my Providers, show me the channels you have available for them". And now that it has the East and West feeds for each, it's so much easier to pick the right one for your location.
The headline for 1.5.1 is Spectrum TV - PrismCast's seventh supported provider, including local affiliate support. Thanks to @scottuf for the collaboration on getting Spectrum up and running.
This release also expands DirecTV Stream and Sling TV coverage significantly — 40+ new channel variants across both providers, including local affiliate support for DirecTV Stream. Thanks to @anon38303228 and @bnhf for the contributions.
On the UI side, the channels tab Quick Actions menu has been consolidated with live toggle counts for predefined channel scopes, bulk provider assignment, and a channel summary showing the breakdown of predefined vs. user channels.
To reiterate from prior release notes:
If you’ve created user-defined channels that are now covered by predefined options, I recommend deleting those overrides and using the defaults. Predefined channels are what I test and maintain; overrides are entirely optional, but they do create long-term configuration debt for you as PrismCast evolves.
I really appreciate the feedback, enthusiasm, and passion around PrismCast. Almost every feature added since 1.0.0 has come from thoughtful, respectful discussion with this community.
My only ask is simple: please be kind, not demanding. PrismCast started as a project for my own needs, and I share it because I enjoy this community and wanted to give something back. Respectful feedback is always welcome; entitlement is not.
Thank you to everyone who’s shared encouragement or joy in using PrismCast—it genuinely keeps this project fun to work on.
One more note for everyone’s benefit: please don’t repost the same questions in this thread. Many of them have already been asked and answered, and the forum’s topic-only search works well. Keeping discussions focused helps everyone. Please treat the thread and each other with the same consideration you’d expect in return.
1.5.1 (2026-03-01)
- New feature: Spectrum TV provider support inclusive of local affiliates. Thanks to @scottuf for the collaboration.
- Improvement: added 40+ DirecTV Stream (thanks to @anon38303228) and Sling channel variants (thanks to @bnhf), including local affiliate support for DirecTV Stream.
- Improvement: webUI refinements - consolidated Quick Actions menu with live toggle counts for predefined channel scopes, bulk provider assignment, and a channel summary showing predefined and user channel breakdown.
- Housekeeping.
Glad you're enjoying it and it's working well! That's a lot of utilization!
For comparison: on my Mac Studio...I barely break 15% with workloads like that.
At this point...I think the only major provider I've heard requests for that hasn't been implemented yet is Xfinity. If someone would like to reach out to me who would be willing to create a sub account for me so I can provide support for it, I'm sure the community would appreciate it.
Oh my. I paid $400.
When would be a good time to upgrade to a Mac? I gotta get Blueiris in there somehow.
What's the easiest way to do this. I thought there was a delete action in prior versions, but I'm not seeing that. I reset all settings to defaults, but that didn't remove all of the custom mappings.
Same as always, just with prettier icons for the past few versions. When overriding builtins:
When a true user-defined channel, it'll be a trashcan icon.
