Invalid SSL Cert - Remote DVR
My Remote Access shows as connected, but says the SSL cert is invalid. What should I do to correct that? Thanks!
Can you submit diagnostics
Logs have been submitted as d597daad-bdbc-4892-baef-85e449af8f9c
Uploading fix, try updating to pre-release in 20min
Build is ready
That fixed it - thanks!
My SSL cert is showing as invalid again. Logs submitted: a7f8bb0b-fb5f-43a3-bd74-5700a7840927
2021/01/29 10:48:57.751480 [TLS] Requesting certificate for ...
Looks like it is working and you just needed to wait a few more minutes? If it's still broken submit diagnostics so we can see the failure.
Yep, it’s working. I just jumped the gun. Thanks!
