Just updated to th7.19 iOS. If I select a show in the guide, then click “record”, I get a recording options screen. If I select Record there, it takes me back one screen, and the button still says “record”. If I go back to the guide it’s colored. or instead if I click record again then cancel, the button gets updated to “recording” or “scheduled”, as appropriate.
It just doesn’t update that screen immediately after visiting the record options screen.
