IPTV Connection Limits
So i'm over TV Everywhere dropping channels (especially locals) and am moving to IPTV. Has anyone figured out the connections issue though? Seems like all the IPTV providers limit the amount of connections so you cant record a couple channels and watch another channel at the same time.
I have a big family and sometimes there are 7 or more channels being watched at once.
Any solutions?
No. The IPTV provider has ability to set stream limit. If you want more streams you have to buy a higher tier plan that allows more concurrent streams.
Reason TVE was able to go over stream limit is because the provider was only limiting the number of streams in their app. They where not limating the number of logins to TVE.
What provider offers the most concurrent high quality hls streams?
When refering to IPTV i assume you are refering to illegal streaming services. We typically do not discuss them in detail here. The illegal nature of them means providers are constantly coming and going. Do NOT prepay for a year subscription from one of these. They are frequently shut down and you will lose your money. Many IPTV providers will have different price levels depending on how many concurrent streams you want.
Good luck.
