Is channels using an old FFMPEG? - ARC a310 not working properly
I have been using channels-dvr for a few years now, for the last 2 years i've been using an intel arc A310 and never really checked if channels is using it properly as I never transcode with channels.
I recently re-installed ubuntu to upgrade to 26.04 server minimal and have set channels back up.
I had a look under Hardware Transcoder Probe and it seems to have a lot of errors but might work?
I asked google's AI to read through it and it is convinced that there are issues and it is due to an old ffmpeg version... but I have my doubts about how accurate this is given that ARC has been around for 4 years now.
Here is my docker compose:
services:
  channels-dvr:
    image: fancybits/channels-dvr:latest
    container_name: channels-dvr
    networks:
      lan_net:
        ipv4_address: 192.168.20.2
    restart: always
    devices:
      - /dev/dri:/dev/dri
    volumes:
      - /mnt/Lambo/Docker-Configs/Channels/config:/channels-dvr
      - /mnt/Lambo/Docker-Configs/Channels/dvr:/shares/DVR
networks:
  lan_net:
    external: true
h264_amf
fork/exec /channels-dvr/2026.08.29.0133/ffmpeg-dl: no such file or directory
h264_nvenc
h264_nvenc+deint
h264_nvenc+scaler
h264_nvenc+tonemap
h264_vaapi@/dev/dri/card0
[AVHWDeviceContext @ 0x42c8fc40] libva: VA-API version 1.22.0
DRM_IOCTL_I915_GEM_APERTURE failed: Invalid argument
Assuming 131072kB available aperture size.
May lead to reduced performance or incorrect rendering.
get chip id failed: -1 [22]
param: 4, val: 0
i915 does not support EXECBUFER2
[AVHWDeviceContext @ 0x42c8fc40] libva: va_openDriver() returns 0
[AVHWDeviceContext @ 0x42c8fc40] Initialised VAAPI connection: version 1.22
[AVHWDeviceContext @ 0x42c8fc40] VAAPI driver: Intel iHD driver for Intel(R) Gen Graphics - 25.3.2 (f37a667).
[AVHWDeviceContext @ 0x42c8fc40] Driver not found in known nonstandard list, using standard behaviour.
[Parsed_testsrc_0 @ 0x42d59d00] size:1280x720 rate:60/1 duration:-1.000000 sar:1/1
[auto_scale_0 @ 0x42d5ac80] w:iw h:ih flags:'' interl:0
[Parsed_format_1 @ 0x42d5a0c0] auto-inserting filter 'auto_scale_0' between the filter 'Parsed_testsrc_0' and the filter 'Parsed_format_1'
[auto_scale_1 @ 0x42d699c0] w:iw h:ih flags:'' interl:0
[Parsed_colorspace_2 @ 0x42d5a4c0] auto-inserting filter 'auto_scale_1' between the filter 'Parsed_format_1' and the filter 'Parsed_colorspace_2'
[auto_scale_0 @ 0x42d5ac80] w:1280 h:720 fmt:rgb24 sar:1/1 -> w:1280 h:720 fmt:p010le sar:1/1 flags:0x00000004
[auto_scale_1 @ 0x42d699c0] w:1280 h:720 fmt:p010le sar:1/1 -> w:1280 h:720 fmt:yuv420p10le sar:1/1 flags:0x00000004
    Last message repeated 3 times
Input #0, lavfi, from 'testsrc=size=1280x720:rate=60,format=p010le,colorspace=all=bt2020:iall=bt2020:fast=0':
  Stream #0:0: Video: wrapped_avframe, 1 reference frame, yuv420p10le(bt2020nc/bt2020/smpte2084), 1280x720 [SAR 1:1 DAR 16:9], 60 fps, 60 tbr, 60 tbn
Stream mapping:
  Stream #0:0 -> #0:0 (wrapped_avframe (native) -> h264 (h264_vaapi))
[graph 0 input from stream 0:0 @ 0x4354ae40] w:1280 h:720 pixfmt:yuv420p10le tb:1/60 fr:60/1 sar:1/1
[auto_scale_0 @ 0x4354a200] w:iw h:ih flags:'' interl:0
[trim_in_0_0 @ 0x4354b240] auto-inserting filter 'auto_scale_0' between the filter 'graph 0 input from stream 0:0' and the filter 'trim_in_0_0'
[auto_scale_0 @ 0x4354a200] w:1280 h:720 fmt:yuv420p10le sar:1/1 -> w:1280 h:720 fmt:nv12 sar:1/1 flags:0x00000004
[h264_vaapi @ 0x43544fc0] Using input frames context (format vaapi) with h264_vaapi encoder.
[h264_vaapi @ 0x43544fc0] Input surface format is nv12.
[h264_vaapi @ 0x43544fc0] Using VAAPI profile VAProfileH264High (7).
[h264_vaapi @ 0x43544fc0] Using VAAPI entrypoint VAEntrypointEncSliceLP (8).
[h264_vaapi @ 0x43544fc0] Using VAAPI render target format YUV420 (0x1).
[h264_vaapi @ 0x43544fc0] RC mode: VBR.
[h264_vaapi @ 0x43544fc0] RC target: 66% of 6000000 bps over 1000 ms.
[h264_vaapi @ 0x43544fc0] RC buffer: 6000000 bits, initial fullness 4500000 bits.
[h264_vaapi @ 0x43544fc0] RC framerate: 60/1 (60.00 fps).
[h264_vaapi @ 0x43544fc0] Driver does not report any additional prediction constraints.
[h264_vaapi @ 0x43544fc0] Using intra, P- and B-frames (supported references: 3 / 1).
[h264_vaapi @ 0x43544fc0] All wanted packed headers available (wanted 0xd, found 0x1f).
Output #0, null, to '/dev/null':
  Metadata:
    encoder         : Lavf60.3.100
  Stream #0:0: Video: h264 (High), 1 reference frame, vaapi(tv, bt2020nc/bt2020/bt2020-10, progressive), 1280x720 (0x0) [SAR 1:1 DAR 16:9], q=2-31, 4000 kb/s, 60 fps, 60 tbn
    Metadata:
      encoder         : Lavc60.3.100 h264_vaapi
[LIBVA]:CRITICAL - DdiMedia_SyncBuffer:4264: Invalid buffer
[LIBVA]:CRITICAL - StatusReport:261: Something unexpected happened in HW, return error to application
[LIBVA]:CRITICAL - StatusReport:261: Something unexpected No more output streams to write to, finishing.
[out#0/null @ 0x43543c80] All streams finished
[out#0/null @ 0x43543c80] Terminating muxer thread
frame=   60 fps=0.0 q=-0.0 Lsize=N/A time=00:00:00.96 bitrate=N/A speed=4.79x
[AVIOContext @ 0x42c8fb00] Statistics: 398 bytes written, 0 seeks, 2 writeouts
video:0kB audio:0kB subtitle:0kB other streams:0kB global headers:0kB muxing overhead: unknown
Input file #0 (testsrc=size=1280x720:rate=60,format=p010le,colorspace=all=bt2020:iall=bt2020:fast=0):
  Input stream #0:0 (video): 61 packets read (29280 bytes); 61 frames decoded;
  Total: 61 packets (29280 bytes) demuxed
Output file #0 (/dev/null):
  Output stream #0:0 (video): 60 frames encoded; 60 packets muxed (0 bytes);
  Total: 60 packets (0 bytes) muxed
Output file is empty, nothing was encoded (check -ss / -t / -frames parameters if used)
Terminating demuxer thread 0
success in 269ms
h264_vaapi@/dev/dri/card0+deint
[AVHWDeviceContext @ 0x14a36c40] libva: VA-API version 1.22.0
param: 4, val: 0
[AVHWDeviceContext @ 0x14a36c40] libva: va_openDriver() returns 0
[AVHWDeviceContext @ 0x14a36c40] Initialised VAAPI connection: version 1.22
[AVHWDeviceContext @ 0x14a36c40] VAAPI driver: Intel iHD driver for Intel(R) Gen Graphics - 25.3.2 (f37a667).
[AVHWDeviceContext @ 0x14a36c40] Driver not found in known nonstandard list, using standard behaviour.
[Parsed_testsrc_0 @ 0x14b00d00] size:1280x720 rate:60/1 duration:-1.000000 sar:1/1
[auto_scale_0 @ 0x14b01c80] w:iw h:ih flags:'' interl:0
[Parsed_format_1 @ 0x14b010c0] auto-inserting filter 'auto_scale_0' between the filter 'Parsed_testsrc_0' and the filter 'Parsed_format_1'
[auto_scale_1 @ 0x14b109c0] w:iw h:ih flags:'' interl:0
[Parsed_colorspace_2 @ 0x14b014c0] auto-inserting filter 'auto_scale_1' between the filter 'Parsed_format_1' and the filter 'Parsed_colorspace_2'
[auto_scale_0 @ 0x14b01c80] w:1280 h:720 fmt:rgb24 sar:1/1 -> w:1280 h:720 fmt:p010le sar:1/1 flags:0x00000004
[auto_scale_1 @ 0x14b109c0] w:1280 h:720 fmt:p010le sar:1/1 -> w:1280 h:720 fmt:yuv420p10le sar:1/1 flags:0x00000004
Stream mapping:
[graph 0 input from stream 0:0 @ 0x152f23c0] w:1280 h:720 pixfmt:yuv420p10le tb:1/60 fr:60/1 sar:1/1
[auto_scale_0 @ 0x152f2cc0] w:iw h:ih flags:'' interl:0
[trim_in_0_0 @ 0x152f2e00] auto-inserting filter 'auto_scale_0' between the filter 'graph 0 input from stream 0:0' and the filter 'trim_in_0_0'
[auto_scale_0 @ 0x152f2cc0] w:1280 h:720 fmt:yuv420p10le sar:1/1 -> w:1280 h:720 fmt:nv12 sar:1/1 flags:0x00000004
[Parsed_deinterlace_vaapi_2 @ 0x152f1b40] Picking 4 (MotionCompensated) as default deinterlacing mode.
    Last message repeated 2 times
[h264_vaapi @ 0x152ebfc0] Using input frames context (format vaapi) with h264_vaapi encoder.
[h264_vaapi @ 0x152ebfc0] Input surface format is nv12.
[h264_vaapi @ 0x152ebfc0] Using VAAPI profile VAProfileH264High (7).
[h264_vaapi @ 0x152ebfc0] Using VAAPI entrypoint VAEntrypointEncSliceLP (8).
[h264_vaapi @ 0x152ebfc0] Using VAAPI render target format YUV420 (0x1).
[h264_vaapi @ 0x152ebfc0] RC mode: VBR.
[h264_vaapi @ 0x152ebfc0] RC target: 66% of 6000000 bps over 1000 ms.
[h264_vaapi @ 0x152ebfc0] RC buffer: 6000000 bits, initial fullness 4500000 bits.
[h264_vaapi @ 0x152ebfc0] RC framerate: 60/1 (60.00 fps).
[h264_vaapi @ 0x152ebfc0] Driver does not report any additional prediction constraints.
[h264_vaapi @ 0x152ebfc0] Using intra, P- and B-frames (supported references: 3 / 1).
[h264_vaapi @ 0x152ebfc0] All wanted packed headers available (wanted 0xd, found 0x1f).
  Metadata:
    Metadata:
[VP]:   CRITICAL - IsFeatureEnabled:507: DI: pDeinterlaceParams != NULL and SampleType = SAMPLE_PROGRESSIVE, driver disable DI
[LIBVA]:CRITICAL - StatusReport:261: SomeNo more output streams to write to, finishing.
[out#0/null @ 0x152eac80] All streams finished
[out#0/null @ 0x152eac80] Terminating muxer thread
frame=   59 fps=0.0 q=-0.0 Lsize=N/A time=00:00:00.96 bitrate=N/A speed=3.41x
[AVIOContext @ 0x14a36b00] Statistics: 398 bytes written, 0 seeks, 2 writeouts
  Output stream #0:0 (video): 59 frames encoded; 59 packets muxed (0 bytes);
  Total: 59 packets (0 bytes) muxed
success in 350ms
h264_vaapi@/dev/dri/card0+deint+tonemap
[AVHWDeviceContext @ 0x274b0c40] libva: VA-API version 1.22.0
param: 4, val: 0
[AVHWDeviceContext @ 0x274b0c40] libva: va_openDriver() returns 0
[AVHWDeviceContext @ 0x274b0c40] Initialised VAAPI connection: version 1.22
[AVHWDeviceContext @ 0x274b0c40] VAAPI driver: Intel iHD driver for Intel(R) Gen Graphics - 25.3.2 (f37a667).
[AVHWDeviceContext @ 0x274b0c40] Driver not found in known nonstandard list, using standard behaviour.
[Parsed_testsrc_0 @ 0x2757ad00] size:1280x720 rate:60/1 duration:-1.000000 sar:1/1
[auto_scale_0 @ 0x2757bc80] w:iw h:ih flags:'' interl:0
[Parsed_format_1 @ 0x2757b0c0] auto-inserting filter 'auto_scale_0' between the filter 'Parsed_testsrc_0' and the filter 'Parsed_format_1'
[auto_scale_1 @ 0x2758a9c0] w:iw h:ih flags:'' interl:0
[Parsed_colorspace_2 @ 0x2757b4c0] auto-inserting filter 'auto_scale_1' between the filter 'Parsed_format_1' and the filter 'Parsed_colorspace_2'
[auto_scale_0 @ 0x2757bc80] w:1280 h:720 fmt:rgb24 sar:1/1 -> w:1280 h:720 fmt:p010le sar:1/1 flags:0x00000004
[auto_scale_1 @ 0x2758a9c0] w:1280 h:720 fmt:p010le sar:1/1 -> w:1280 h:720 fmt:yuv420p10le sar:1/1 flags:0x00000004
Stream mapping:
[graph 0 input from stream 0:0 @ 0x27d6c0c0] w:1280 h:720 pixfmt:yuv420p10le tb:1/60 fr:60/1 sar:1/1
[auto_scale_0 @ 0x27d6d880] w:iw h:ih flags:'' interl:0
[trim_in_0_0 @ 0x27d6c680] auto-inserting filter 'auto_scale_0' between the filter 'graph 0 input from stream 0:0' and the filter 'trim_in_0_0'
[auto_scale_0 @ 0x27d6d880] w:1280 h:720 fmt:yuv420p10le sar:1/1 -> w:1280 h:720 fmt:p010le sar:1/1 flags:0x00000004
[Parsed_tonemap_vaapi_1 @ 0x27d6bc00] Only support HDR10 as input for vaapi tone-mapping
[Parsed_tonemap_vaapi_1 @ 0x27d6bc00] No mastering display data from input
Error while filtering: Invalid argument
Failed to inject frame into filter network: Invalid argument
Error while processing the decoded data for stream #0:0
Conversion failed!
exit status 1
h264_vaapi@/dev/dri/renderD128
[AVHWDeviceContext @ 0xcb17c40] libva: VA-API version 1.22.0
param: 4, val: 0
[AVHWDeviceContext @ 0xcb17c40] libva: va_openDriver() returns 0
[AVHWDeviceContext @ 0xcb17c40] Initialised VAAPI connection: version 1.22
[AVHWDeviceContext @ 0xcb17c40] VAAPI driver: Intel iHD driver for Intel(R) Gen Graphics - 25.3.2 (f37a667).
[AVHWDeviceContext @ 0xcb17c40] Driver not found in known nonstandard list, using standard behaviour.
[Parsed_testsrc_0 @ 0xcbe1d00] size:1280x720 rate:60/1 duration:-1.000000 sar:1/1
[auto_scale_0 @ 0xcbe2c80] w:iw h:ih flags:'' interl:0
[Parsed_format_1 @ 0xcbe20c0] auto-inserting filter 'auto_scale_0' between the filter 'Parsed_testsrc_0' and the filter 'Parsed_format_1'
[auto_scale_1 @ 0xcbf19c0] w:iw h:ih flags:'' interl:0
[Parsed_colorspace_2 @ 0xcbe24c0] auto-inserting filter 'auto_scale_1' between the filter 'Parsed_format_1' and the filter 'Parsed_colorspace_2'
[auto_scale_0 @ 0xcbe2c80] w:1280 h:720 fmt:rgb24 sar:1/1 -> w:1280 h:720 fmt:p010le sar:1/1 flags:0x00000004
[auto_scale_1 @ 0xcbf19c0] w:1280 h:720 fmt:p010le sar:1/1 -> w:1280 h:720 fmt:yuv420p10le sar:1/1 flags:0x00000004
Stream mapping:
[graph 0 input from stream 0:0 @ 0xd3d2e40] w:1280 h:720 pixfmt:yuv420p10le tb:1/60 fr:60/1 sar:1/1
[auto_scale_0 @ 0xd3d2200] w:iw h:ih flags:'' interl:0
[trim_in_0_0 @ 0xd3d3240] auto-inserting filter 'auto_scale_0' between the filter 'graph 0 input from stream 0:0' and the filter 'trim_in_0_0'
[auto_scale_0 @ 0xd3d2200] w:1280 h:720 fmt:yuv420p10le sar:1/1 -> w:1280 h:720 fmt:nv12 sar:1/1 flags:0x00000004
[h264_vaapi @ 0xd3ccfc0] Using input frames context (format vaapi) with h264_vaapi encoder.
[h264_vaapi @ 0xd3ccfc0] Input surface format is nv12.
[h264_vaapi @ 0xd3ccfc0] Using VAAPI profile VAProfileH264High (7).
[h264_vaapi @ 0xd3ccfc0] Using VAAPI entrypoint VAEntrypointEncSliceLP (8).
[h264_vaapi @ 0xd3ccfc0] Using VAAPI render target format YUV420 (0x1).
[h264_vaapi @ 0xd3ccfc0] RC mode: VBR.
[h264_vaapi @ 0xd3ccfc0] RC target: 66% of 6000000 bps over 1000 ms.
[h264_vaapi @ 0xd3ccfc0] RC buffer: 6000000 bits, initial fullness 4500000 bits.
[h264_vaapi @ 0xd3ccfc0] RC framerate: 60/1 (60.00 fps).
[h264_vaapi @ 0xd3ccfc0] Driver does not report any additional prediction constraints.
[h264_vaapi @ 0xd3ccfc0] Using intra, P- and B-frames (supported references: 3 / 1).
[h264_vaapi @ 0xd3ccfc0] All wanted packed headers available (wanted 0xd, found 0x1f).
  Metadata:
    Metadata:
[out#0/null @ 0xd3cbc80] All streams finished
[out#0/null @ 0xd3cbc80] Terminating muxer thread
frame=   60 fps=0.0 q=-0.0 Lsize=N/A time=00:00:00.96 bitrate=N/A speed=4.85x
[AVIOContext @ 0xcb17b00] Statistics: 398 bytes written, 0 seeks, 2 writeouts
success in 260ms
h264_vaapi@/dev/dri/renderD128+deint
[AVHWDeviceContext @ 0x486f0c40] libva: VA-API version 1.22.0
param: 4, val: 0
[AVHWDeviceContext @ 0x486f0c40] libva: va_openDriver() returns 0
[AVHWDeviceContext @ 0x486f0c40] Initialised VAAPI connection: version 1.22
[AVHWDeviceContext @ 0x486f0c40] VAAPI driver: Intel iHD driver for Intel(R) Gen Graphics - 25.3.2 (f37a667).
[AVHWDeviceContext @ 0x486f0c40] Driver not found in known nonstandard list, using standard behaviour.
[Parsed_testsrc_0 @ 0x487bad00] size:1280x720 rate:60/1 duration:-1.000000 sar:1/1
[auto_scale_0 @ 0x487bbc80] w:iw h:ih flags:'' interl:0
[Parsed_format_1 @ 0x487bb0c0] auto-inserting filter 'auto_scale_0' between the filter 'Parsed_testsrc_0' and the filter 'Parsed_format_1'
[auto_scale_1 @ 0x487ca9c0] w:iw h:ih flags:'' interl:0
[Parsed_colorspace_2 @ 0x487bb4c0] auto-inserting filter 'auto_scale_1' between the filter 'Parsed_format_1' and the filter 'Parsed_colorspace_2'
[auto_scale_0 @ 0x487bbc80] w:1280 h:720 fmt:rgb24 sar:1/1 -> w:1280 h:720 fmt:p010le sar:1/1 flags:0x00000004
[auto_scale_1 @ 0x487ca9c0] w:1280 h:720 fmt:p010le sar:1/1 -> w:1280 h:720 fmt:yuv420p10le sar:1/1 flags:0x00000004
Stream mapping:
[graph 0 input from stream 0:0 @ 0x48fac3c0] w:1280 h:720 pixfmt:yuv420p10le tb:1/60 fr:60/1 sar:1/1
[auto_scale_0 @ 0x48faccc0] w:iw h:ih flags:'' interl:0
[trim_in_0_0 @ 0x48face00] auto-inserting filter 'auto_scale_0' between the filter 'graph 0 input from stream 0:0' and the filter 'trim_in_0_0'
[auto_scale_0 @ 0x48faccc0] w:1280 h:720 fmt:yuv420p10le sar:1/1 -> w:1280 h:720 fmt:nv12 sar:1/1 flags:0x00000004
[Parsed_deinterlace_vaapi_2 @ 0x48fabb40] Picking 4 (MotionCompensated) as default deinterlacing mode.
[h264_vaapi @ 0x48fa5fc0] Using input frames context (format vaapi) with h264_vaapi encoder.
[h264_vaapi @ 0x48fa5fc0] Input surface format is nv12.
[h264_vaapi @ 0x48fa5fc0] Using VAAPI profile VAProfileH264High (7).
[h264_vaapi @ 0x48fa5fc0] Using VAAPI entrypoint VAEntrypointEncSliceLP (8).
[h264_vaapi @ 0x48fa5fc0] Using VAAPI render target format YUV420 (0x1).
[h264_vaapi @ 0x48fa5fc0] RC mode: VBR.
[h264_vaapi @ 0x48fa5fc0] RC target: 66% of 6000000 bps over 1000 ms.
[h264_vaapi @ 0x48fa5fc0] RC buffer: 6000000 bits, initial fullness 4500000 bits.
[h264_vaapi @ 0x48fa5fc0] RC framerate: 60/1 (60.00 fps).
[h264_vaapi @ 0x48fa5fc0] Driver does not report any additional prediction constraints.
[h264_vaapi @ 0x48fa5fc0] Using intra, P- and B-frames (supported references: 3 / 1).
[h264_vaapi @ 0x48fa5fc0] All wanted packed headers available (wanted 0xd, found 0x1f).
  Metadata:
    Metadata:
[out#0/null @ 0x48fa4c80] All streams finished
[out#0/null @ 0x48fa4c80] Terminating muxer thread
frame=   59 fps=0.0 q=-0.0 Lsize=N/A time=00:00:00.96 bitrate=N/A speed=3.38x
[AVIOContext @ 0x486f0b00] Statistics: 398 bytes written, 0 seeks, 2 writeouts
success in 367ms
h264_vaapi@/dev/dri/renderD128+deint+tonemap
[AVHWDeviceContext @ 0x367ccc40] libva: VA-API version 1.22.0
param: 4, val: 0
[AVHWDeviceContext @ 0x367ccc40] libva: va_openDriver() returns 0
[AVHWDeviceContext @ 0x367ccc40] Initialised VAAPI connection: version 1.22
[AVHWDeviceContext @ 0x367ccc40] VAAPI driver: Intel iHD driver for Intel(R) Gen Graphics - 25.3.2 (f37a667).
[AVHWDeviceContext @ 0x367ccc40] Driver not found in known nonstandard list, using standard behaviour.
[Parsed_testsrc_0 @ 0x36896d00] size:1280x720 rate:60/1 duration:-1.000000 sar:1/1
[auto_scale_0 @ 0x36897c80] w:iw h:ih flags:'' interl:0
[Parsed_format_1 @ 0x368970c0] auto-inserting filter 'auto_scale_0' between the filter 'Parsed_testsrc_0' and the filter 'Parsed_format_1'
[auto_scale_1 @ 0x368a69c0] w:iw h:ih flags:'' interl:0
[Parsed_colorspace_2 @ 0x368974c0] auto-inserting filter 'auto_scale_1' between the filter 'Parsed_format_1' and the filter 'Parsed_colorspace_2'
[auto_scale_0 @ 0x36897c80] w:1280 h:720 fmt:rgb24 sar:1/1 -> w:1280 h:720 fmt:p010le sar:1/1 flags:0x00000004
[auto_scale_1 @ 0x368a69c0] w:1280 h:720 fmt:p010le sar:1/1 -> w:1280 h:720 fmt:yuv420p10le sar:1/1 flags:0x00000004
Stream mapping:
[graph 0 input from stream 0:0 @ 0x370880c0] w:1280 h:720 pixfmt:yuv420p10le tb:1/60 fr:60/1 sar:1/1
[auto_scale_0 @ 0x37089880] w:iw h:ih flags:'' interl:0
[trim_in_0_0 @ 0x37088680] auto-inserting filter 'auto_scale_0' between the filter 'graph 0 input from stream 0:0' and the filter 'trim_in_0_0'
[auto_scale_0 @ 0x37089880] w:1280 h:720 fmt:yuv420p10le sar:1/1 -> w:1280 h:720 fmt:p010le sar:1/1 flags:0x00000004
[Parsed_tonemap_vaapi_1 @ 0x37087c00] Only support HDR10 as input for vaapi tone-mapping
[Parsed_tonemap_vaapi_1 @ 0x37087c00] No mastering display data from input
Conversion failed!
exit status 1
h264_vaapi@/dev/dri/renderD129
h264_vaapi@/dev/renderD128
You could try installing jammy intel drivers. I wrote up a how to when I had this issue going from 22 to 24. It may or may not work for 26. Here is a link to that post.
Please try this pre-release build.
Also note, my CPU has an i-gpu (11th gen intel) so i technically have two GPUs in the NAS. I'm not sure how channels handles this.
root@apollo:~# ls /dev/dri
by-path  card0  card1  renderD128  renderD129
root@apollo:~#
Here is the output from 2026.08.29.2212:
h264_amf
fork/exec /channels-dvr/2026.08.29.2212/ffmpeg-dl: no such file or directory
h264_nvenc
h264_nvenc+deint
h264_nvenc+scaler
h264_nvenc+tonemap
[AVHWDeviceContext @ 0xe64bf80] libva: VA-API version 1.24.0
param: 4, val: 0
[AVHWDeviceContext @ 0xe64bf80] libva: va_openDriver() returns 0
[AVHWDeviceContext @ 0xe64bf80] Initialised VAAPI connection: version 1.24
[AVHWDeviceContext @ 0xe64bf80] VAAPI driver: Intel iHD driver for Intel(R) Gen Graphics - 26.3.2 (1240c65).
[AVHWDeviceContext @ 0xe64bf80] Driver not found in known nonstandard list, using standard behaviour.
[Parsed_testsrc_0 @ 0xe726fc0] size:1280x720 rate:60/1 duration:-1.000000 sar:1/1
[auto_scale_0 @ 0xe67e580] w:iw h:ih flags:'' interl:0
[Parsed_format_1 @ 0xe727280] auto-inserting filter 'auto_scale_0' between the filter 'Parsed_testsrc_0' and the filter 'Parsed_format_1'
[auto_scale_1 @ 0xe736a00] w:iw h:ih flags:'' interl:0
[Parsed_colorspace_2 @ 0xe7275c0] auto-inserting filter 'auto_scale_1' between the filter 'Parsed_format_1' and the filter 'Parsed_colorspace_2'
[auto_scale_0 @ 0xe67e580] w:1280 h:720 fmt:rgb24 sar:1/1 -> w:1280 h:720 fmt:p010le sar:1/1 flags:0x00000004
[auto_scale_1 @ 0xe736a00] w:1280 h:720 fmt:p010le sar:1/1 -> w:1280 h:720 fmt:yuv420p10le sar:1/1 flags:0x00000004
Stream mapping:
[graph 0 input from stream 0:0 @ 0xef17c40] w:1280 h:720 pixfmt:yuv420p10le tb:1/60 fr:60/1 sar:1/1
[auto_scale_0 @ 0xef18f40] w:iw h:ih flags:'' interl:0
[trim_in_0_0 @ 0xef17dc0] auto-inserting filter 'auto_scale_0' between the filter 'graph 0 input from stream 0:0' and the filter 'trim_in_0_0'
[auto_scale_0 @ 0xef18f40] w:1280 h:720 fmt:yuv420p10le sar:1/1 -> w:1280 h:720 fmt:nv12 sar:1/1 flags:0x00000004
[h264_vaapi @ 0xef11f40] Using input frames context (format vaapi) with h264_vaapi encoder.
[h264_vaapi @ 0xef11f40] Input surface format is nv12.
[h264_vaapi @ 0xef11f40] Using VAAPI profile VAProfileH264High (7).
[h264_vaapi @ 0xef11f40] Using VAAPI entrypoint VAEntrypointEncSliceLP (8).
[h264_vaapi @ 0xef11f40] Using VAAPI render target format YUV420 (0x1).
[h264_vaapi @ 0xef11f40] RC mode: VBR.
[h264_vaapi @ 0xef11f40] RC target: 66% of 6000000 bps over 1000 ms.
[h264_vaapi @ 0xef11f40] RC buffer: 6000000 bits, initial fullness 4500000 bits.
[h264_vaapi @ 0xef11f40] RC framerate: 60/1 (60.00 fps).
[h264_vaapi @ 0xef11f40] Driver does not report any additional prediction constraints.
[h264_vaapi @ 0xef11f40] Using intra, P- and B-frames (supported references: 3 / 1).
[h264_vaapi @ 0xef11f40] All wanted packed headers available (wanted 0xd, found 0x1f).
  Metadata:
    Metadata:
[LIBVA]:CRITICAL - DdiMedia_SyncBuffer:4260: Invalid buffer
[out#0/null @ 0xeec1bc0] All streams finished
[out#0/null @ 0xeec1bc0] Terminating muxer thread
frame=   60 fps=0.0 q=-0.0 Lsize=N/A time=00:00:00.96 bitrate=N/A speed=4.77x
[AVIOContext @ 0xe654200] Statistics: 398 bytes written, 0 seeks, 2 writeouts
success in 256ms
[AVHWDeviceContext @ 0x3f10cf80] libva: VA-API version 1.24.0
param: 4, val: 0
[AVHWDeviceContext @ 0x3f10cf80] libva: va_openDriver() returns 0
[AVHWDeviceContext @ 0x3f10cf80] Initialised VAAPI connection: version 1.24
[AVHWDeviceContext @ 0x3f10cf80] VAAPI driver: Intel iHD driver for Intel(R) Gen Graphics - 26.3.2 (1240c65).
[AVHWDeviceContext @ 0x3f10cf80] Driver not found in known nonstandard list, using standard behaviour.
[Parsed_testsrc_0 @ 0x3f1e7fc0] size:1280x720 rate:60/1 duration:-1.000000 sar:1/1
[auto_scale_0 @ 0x3f13f580] w:iw h:ih flags:'' interl:0
[Parsed_format_1 @ 0x3f1e8280] auto-inserting filter 'auto_scale_0' between the filter 'Parsed_testsrc_0' and the filter 'Parsed_format_1'
[auto_scale_1 @ 0x3f1f7a00] w:iw h:ih flags:'' interl:0
[Parsed_colorspace_2 @ 0x3f1e85c0] auto-inserting filter 'auto_scale_1' between the filter 'Parsed_format_1' and the filter 'Parsed_colorspace_2'
[auto_scale_0 @ 0x3f13f580] w:1280 h:720 fmt:rgb24 sar:1/1 -> w:1280 h:720 fmt:p010le sar:1/1 flags:0x00000004
[auto_scale_1 @ 0x3f1f7a00] w:1280 h:720 fmt:p010le sar:1/1 -> w:1280 h:720 fmt:yuv420p10le sar:1/1 flags:0x00000004
Stream mapping:
[graph 0 input from stream 0:0 @ 0x3f9d9440] w:1280 h:720 pixfmt:yuv420p10le tb:1/60 fr:60/1 sar:1/1
[auto_scale_0 @ 0x3f9d7e80] w:iw h:ih flags:'' interl:0
[trim_in_0_0 @ 0x3f9d9900] auto-inserting filter 'auto_scale_0' between the filter 'graph 0 input from stream 0:0' and the filter 'trim_in_0_0'
[auto_scale_0 @ 0x3f9d7e80] w:1280 h:720 fmt:yuv420p10le sar:1/1 -> w:1280 h:720 fmt:nv12 sar:1/1 flags:0x00000004
[Parsed_deinterlace_vaapi_2 @ 0x3f9d8cc0] Picking 4 (MotionCompensated) as default deinterlacing mode.
[h264_vaapi @ 0x3f9d2f40] Using input frames context (format vaapi) with h264_vaapi encoder.
[h264_vaapi @ 0x3f9d2f40] Input surface format is nv12.
[h264_vaapi @ 0x3f9d2f40] Using VAAPI profile VAProfileH264High (7).
[h264_vaapi @ 0x3f9d2f40] Using VAAPI entrypoint VAEntrypointEncSliceLP (8).
[h264_vaapi @ 0x3f9d2f40] Using VAAPI render target format YUV420 (0x1).
[h264_vaapi @ 0x3f9d2f40] RC mode: VBR.
[h264_vaapi @ 0x3f9d2f40] RC target: 66% of 6000000 bps over 1000 ms.
[h264_vaapi @ 0x3f9d2f40] RC buffer: 6000000 bits, initial fullness 4500000 bits.
[h264_vaapi @ 0x3f9d2f40] RC framerate: 60/1 (60.00 fps).
[h264_vaapi @ 0x3f9d2f40] Driver does not report any additional prediction constraints.
[h264_vaapi @ 0x3f9d2f40] Using intra, P- and B-frames (supported references: 3 / 1).
[h264_vaapi @ 0x3f9d2f40] All wanted packed headers available (wanted 0xd, found 0x1f).
  Metadata:
    Metadata:
[out#0/null @ 0x3f982bc0] All streams finished
[out#0/null @ 0x3f982bc0] Terminating muxer thread
frame=   59 fps=0.0 q=-0.0 Lsize=N/A time=00:00:00.96 bitrate=N/A speed=3.39x
[AVIOContext @ 0x3f115200] Statistics: 398 bytes written, 0 seeks, 2 writeouts
success in 343ms
[AVHWDeviceContext @ 0xf4a0f80] libva: VA-API version 1.24.0
param: 4, val: 0
[AVHWDeviceContext @ 0xf4a0f80] libva: va_openDriver() returns 0
[AVHWDeviceContext @ 0xf4a0f80] Initialised VAAPI connection: version 1.24
[AVHWDeviceContext @ 0xf4a0f80] VAAPI driver: Intel iHD driver for Intel(R) Gen Graphics - 26.3.2 (1240c65).
[AVHWDeviceContext @ 0xf4a0f80] Driver not found in known nonstandard list, using standard behaviour.
[Parsed_testsrc_0 @ 0xf57bfc0] size:1280x720 rate:60/1 duration:-1.000000 sar:1/1
[auto_scale_0 @ 0xf4d3580] w:iw h:ih flags:'' interl:0
[Parsed_format_1 @ 0xf57c280] auto-inserting filter 'auto_scale_0' between the filter 'Parsed_testsrc_0' and the filter 'Parsed_format_1'
[auto_scale_1 @ 0xf58ba00] w:iw h:ih flags:'' interl:0
[Parsed_colorspace_2 @ 0xf57c5c0] auto-inserting filter 'auto_scale_1' between the filter 'Parsed_format_1' and the filter 'Parsed_colorspace_2'
[auto_scale_0 @ 0xf4d3580] w:1280 h:720 fmt:rgb24 sar:1/1 -> w:1280 h:720 fmt:p010le sar:1/1 flags:0x00000004
[auto_scale_1 @ 0xf58ba00] w:1280 h:720 fmt:p010le sar:1/1 -> w:1280 h:720 fmt:yuv420p10le sar:1/1 flags:0x00000004
Stream mapping:
[graph 0 input from stream 0:0 @ 0xfd6d380] w:1280 h:720 pixfmt:yuv420p10le tb:1/60 fr:60/1 sar:1/1
[auto_scale_0 @ 0xfd6e3c0] w:iw h:ih flags:'' interl:0
[trim_in_0_0 @ 0xfd6d4c0] auto-inserting filter 'auto_scale_0' between the filter 'graph 0 input from stream 0:0' and the filter 'trim_in_0_0'
[auto_scale_0 @ 0xfd6e3c0] w:1280 h:720 fmt:yuv420p10le sar:1/1 -> w:1280 h:720 fmt:p010le sar:1/1 flags:0x00000004
[Parsed_tonemap_vaapi_1 @ 0xfd6cec0] Only support HDR10 as input for vaapi tone-mapping
[Parsed_tonemap_vaapi_1 @ 0xfd6cec0] No mastering display data from input
Conversion failed!
exit status 1
[AVHWDeviceContext @ 0x1cff1f80] libva: VA-API version 1.24.0
[AVHWDeviceContext @ 0x1cff1f80] libva: va_openDriver() returns 0
[AVHWDeviceContext @ 0x1cff1f80] Initialised VAAPI connection: version 1.24
[AVHWDeviceContext @ 0x1cff1f80] VAAPI driver: Intel iHD driver for Intel(R) Gen Graphics - 26.3.2 (1240c65).
[AVHWDeviceContext @ 0x1cff1f80] Driver not found in known nonstandard list, using standard behaviour.
[Parsed_testsrc_0 @ 0x1d09dd00] size:1280x720 rate:60/1 duration:-1.000000 sar:1/1
[auto_scale_0 @ 0x1d09c740] w:iw h:ih flags:'' interl:0
[Parsed_format_1 @ 0x1d09e300] auto-inserting filter 'auto_scale_0' between the filter 'Parsed_testsrc_0' and the filter 'Parsed_format_1'
[auto_scale_1 @ 0x1d0ad6c0] w:iw h:ih flags:'' interl:0
[Parsed_colorspace_2 @ 0x1d09e580] auto-inserting filter 'auto_scale_1' between the filter 'Parsed_format_1' and the filter 'Parsed_colorspace_2'
[auto_scale_0 @ 0x1d09c740] w:1280 h:720 fmt:rgb24 sar:1/1 -> w:1280 h:720 fmt:p010le sar:1/1 flags:0x00000004
[auto_scale_1 @ 0x1d0ad6c0] w:1280 h:720 fmt:p010le sar:1/1 -> w:1280 h:720 fmt:yuv420p10le sar:1/1 flags:0x00000004
Stream mapping:
[graph 0 input from stream 0:0 @ 0x1d88ea00] w:1280 h:720 pixfmt:yuv420p10le tb:1/60 fr:60/1 sar:1/1
[auto_scale_0 @ 0x1d890080] w:iw h:ih flags:'' interl:0
[trim_in_0_0 @ 0x1d88ee80] auto-inserting filter 'auto_scale_0' between the filter 'graph 0 input from stream 0:0' and the filter 'trim_in_0_0'
[auto_scale_0 @ 0x1d890080] w:1280 h:720 fmt:yuv420p10le sar:1/1 -> w:1280 h:720 fmt:nv12 sar:1/1 flags:0x00000004
[h264_vaapi @ 0x1d889000] Using input frames context (format vaapi) with h264_vaapi encoder.
[h264_vaapi @ 0x1d889000] Input surface format is nv12.
[h264_vaapi @ 0x1d889000] Using VAAPI profile VAProfileH264High (7).
[h264_vaapi @ 0x1d889000] Using VAAPI entrypoint VAEntrypointEncSlice (6).
[h264_vaapi @ 0x1d889000] Using VAAPI render target format YUV420 (0x1).
[h264_vaapi @ 0x1d889000] RC mode: AVBR.
[h264_vaapi @ 0x1d889000] RC target: 4000000 bps converging in 120 frames with 100% accuracy.
[h264_vaapi @ 0x1d889000] RC framerate: 60/1 (60.00 fps).
[h264_vaapi @ 0x1d889000] Driver does not report any additional prediction constraints.
[h264_vaapi @ 0x1d889000] Using intra, P- and B-frames (supported references: 8 / 2).
[h264_vaapi @ 0x1d889000] All wanted packed headers available (wanted 0xd, found 0x1f).
  Metadata:
    Metadata:
[out#0/null @ 0x1d837e80] All streams finished
[out#0/null @ 0x1d837e80] Terminating muxer thread
frame=   60 fps=0.0 q=-0.0 Lsize=N/A time=00:00:00.96 bitrate=N/A speed=4.74x
[AVIOContext @ 0x1cffa200] Statistics: 398 bytes written, 0 seeks, 2 writeouts
video:36kB audio:0kB subtitle:0kB other streams:0kB global headers:0kB muxing overhead: unknown
  Output stream #0:0 (video): 60 frames encoded; 60 packets muxed (37027 bytes);
  Total: 60 packets (37027 bytes) muxed
success in 228ms
[AVHWDeviceContext @ 0x420fbf80] libva: VA-API version 1.24.0
[AVHWDeviceContext @ 0x420fbf80] libva: va_openDriver() returns 0
[AVHWDeviceContext @ 0x420fbf80] Initialised VAAPI connection: version 1.24
[AVHWDeviceContext @ 0x420fbf80] VAAPI driver: Intel iHD driver for Intel(R) Gen Graphics - 26.3.2 (1240c65).
[AVHWDeviceContext @ 0x420fbf80] Driver not found in known nonstandard list, using standard behaviour.
[Parsed_testsrc_0 @ 0x421a7d00] size:1280x720 rate:60/1 duration:-1.000000 sar:1/1
[auto_scale_0 @ 0x421a6740] w:iw h:ih flags:'' interl:0
[Parsed_format_1 @ 0x421a8300] auto-inserting filter 'auto_scale_0' between the filter 'Parsed_testsrc_0' and the filter 'Parsed_format_1'
[auto_scale_1 @ 0x421b76c0] w:iw h:ih flags:'' interl:0
[Parsed_colorspace_2 @ 0x421a8580] auto-inserting filter 'auto_scale_1' between the filter 'Parsed_format_1' and the filter 'Parsed_colorspace_2'
[auto_scale_0 @ 0x421a6740] w:1280 h:720 fmt:rgb24 sar:1/1 -> w:1280 h:720 fmt:p010le sar:1/1 flags:0x00000004
[auto_scale_1 @ 0x421b76c0] w:1280 h:720 fmt:p010le sar:1/1 -> w:1280 h:720 fmt:yuv420p10le sar:1/1 flags:0x00000004
Stream mapping:
[graph 0 input from stream 0:0 @ 0x42999200] w:1280 h:720 pixfmt:yuv420p10le tb:1/60 fr:60/1 sar:1/1
[auto_scale_0 @ 0x4299a9c0] w:iw h:ih flags:'' interl:0
[trim_in_0_0 @ 0x42999800] auto-inserting filter 'auto_scale_0' between the filter 'graph 0 input from stream 0:0' and the filter 'trim_in_0_0'
[auto_scale_0 @ 0x4299a9c0] w:1280 h:720 fmt:yuv420p10le sar:1/1 -> w:1280 h:720 fmt:nv12 sar:1/1 flags:0x00000004
[Parsed_deinterlace_vaapi_2 @ 0x42998a80] Picking 4 (MotionCompensated) as default deinterlacing mode.
[h264_vaapi @ 0x42993000] Using input frames context (format vaapi) with h264_vaapi encoder.
[h264_vaapi @ 0x42993000] Input surface format is nv12.
[h264_vaapi @ 0x42993000] Using VAAPI profile VAProfileH264High (7).
[h264_vaapi @ 0x42993000] Using VAAPI entrypoint VAEntrypointEncSlice (6).
[h264_vaapi @ 0x42993000] Using VAAPI render target format YUV420 (0x1).
[h264_vaapi @ 0x42993000] RC mode: AVBR.
[h264_vaapi @ 0x42993000] RC target: 4000000 bps converging in 120 frames with 100% accuracy.
[h264_vaapi @ 0x42993000] RC framerate: 60/1 (60.00 fps).
[h264_vaapi @ 0x42993000] Driver does not report any additional prediction constraints.
[h264_vaapi @ 0x42993000] Using intra, P- and B-frames (supported references: 8 / 2).
[h264_vaapi @ 0x42993000] All wanted packed headers available (wanted 0xd, found 0x1f).
  Metadata:
    Metadata:
[out#0/null @ 0x42941e80] All streams finished
[out#0/null @ 0x42941e80] Terminating muxer thread
frame=   59 fps=0.0 q=-0.0 Lsize=N/A time=00:00:00.96 bitrate=N/A speed=4.51x
[AVIOContext @ 0x42104200] Statistics: 398 bytes written, 0 seeks, 2 writeouts
video:39kB audio:0kB subtitle:0kB other streams:0kB global headers:0kB muxing overhead: unknown
  Output stream #0:0 (video): 59 frames encoded; 59 packets muxed (39510 bytes);
  Total: 59 packets (39510 bytes) muxed
success in 240ms
[AVHWDeviceContext @ 0x46babf80] libva: VA-API version 1.24.0
[AVHWDeviceContext @ 0x46babf80] libva: va_openDriver() returns 0
[AVHWDeviceContext @ 0x46babf80] Initialised VAAPI connection: version 1.24
[AVHWDeviceContext @ 0x46babf80] VAAPI driver: Intel iHD driver for Intel(R) Gen Graphics - 26.3.2 (1240c65).
[AVHWDeviceContext @ 0x46babf80] Driver not found in known nonstandard list, using standard behaviour.
[Parsed_testsrc_0 @ 0x46c57d00] size:1280x720 rate:60/1 duration:-1.000000 sar:1/1
[auto_scale_0 @ 0x46c56740] w:iw h:ih flags:'' interl:0
[Parsed_format_1 @ 0x46c58300] auto-inserting filter 'auto_scale_0' between the filter 'Parsed_testsrc_0' and the filter 'Parsed_format_1'
[auto_scale_1 @ 0x46c676c0] w:iw h:ih flags:'' interl:0
[Parsed_colorspace_2 @ 0x46c58580] auto-inserting filter 'auto_scale_1' between the filter 'Parsed_format_1' and the filter 'Parsed_colorspace_2'
[auto_scale_0 @ 0x46c56740] w:1280 h:720 fmt:rgb24 sar:1/1 -> w:1280 h:720 fmt:p010le sar:1/1 flags:0x00000004
[auto_scale_1 @ 0x46c676c0] w:1280 h:720 fmt:p010le sar:1/1 -> w:1280 h:720 fmt:yuv420p10le sar:1/1 flags:0x00000004
Stream mapping:
[graph 0 input from stream 0:0 @ 0x47448ec0] w:1280 h:720 pixfmt:yuv420p10le tb:1/60 fr:60/1 sar:1/1
[auto_scale_0 @ 0x4744a240] w:iw h:ih flags:'' interl:0
[trim_in_0_0 @ 0x47449040] auto-inserting filter 'auto_scale_0' between the filter 'graph 0 input from stream 0:0' and the filter 'trim_in_0_0'
[auto_scale_0 @ 0x4744a240] w:1280 h:720 fmt:yuv420p10le sar:1/1 -> w:1280 h:720 fmt:p010le sar:1/1 flags:0x00000004
[Parsed_tonemap_vaapi_1 @ 0x47448a00] Only support HDR10 as input for vaapi tone-mapping
[Parsed_tonemap_vaapi_1 @ 0x47448a00] No mastering display data from input
Conversion failed!
exit status 1
[AVHWDeviceContext @ 0x49e20f80] libva: VA-API version 1.24.0
param: 4, val: 0
[AVHWDeviceContext @ 0x49e20f80] libva: va_openDriver() returns 0
[AVHWDeviceContext @ 0x49e20f80] Initialised VAAPI connection: version 1.24
[AVHWDeviceContext @ 0x49e20f80] VAAPI driver: Intel iHD driver for Intel(R) Gen Graphics - 26.3.2 (1240c65).
[AVHWDeviceContext @ 0x49e20f80] Driver not found in known nonstandard list, using standard behaviour.
[Parsed_testsrc_0 @ 0x49efbfc0] size:1280x720 rate:60/1 duration:-1.000000 sar:1/1
[auto_scale_0 @ 0x49e53580] w:iw h:ih flags:'' interl:0
[Parsed_format_1 @ 0x49efc280] auto-inserting filter 'auto_scale_0' between the filter 'Parsed_testsrc_0' and the filter 'Parsed_format_1'
[auto_scale_1 @ 0x49f0ba00] w:iw h:ih flags:'' interl:0
[Parsed_colorspace_2 @ 0x49efc5c0] auto-inserting filter 'auto_scale_1' between the filter 'Parsed_format_1' and the filter 'Parsed_colorspace_2'
[auto_scale_0 @ 0x49e53580] w:1280 h:720 fmt:rgb24 sar:1/1 -> w:1280 h:720 fmt:p010le sar:1/1 flags:0x00000004
[auto_scale_1 @ 0x49f0ba00] w:1280 h:720 fmt:p010le sar:1/1 -> w:1280 h:720 fmt:yuv420p10le sar:1/1 flags:0x00000004
Stream mapping:
[graph 0 input from stream 0:0 @ 0x4a6ecc40] w:1280 h:720 pixfmt:yuv420p10le tb:1/60 fr:60/1 sar:1/1
[auto_scale_0 @ 0x4a6edf40] w:iw h:ih flags:'' interl:0
[trim_in_0_0 @ 0x4a6ecdc0] auto-inserting filter 'auto_scale_0' between the filter 'graph 0 input from stream 0:0' and the filter 'trim_in_0_0'
[auto_scale_0 @ 0x4a6edf40] w:1280 h:720 fmt:yuv420p10le sar:1/1 -> w:1280 h:720 fmt:nv12 sar:1/1 flags:0x00000004
[h264_vaapi @ 0x4a6e6f40] Using input frames context (format vaapi) with h264_vaapi encoder.
[h264_vaapi @ 0x4a6e6f40] Input surface format is nv12.
[h264_vaapi @ 0x4a6e6f40] Using VAAPI profile VAProfileH264High (7).
[h264_vaapi @ 0x4a6e6f40] Using VAAPI entrypoint VAEntrypointEncSliceLP (8).
[h264_vaapi @ 0x4a6e6f40] Using VAAPI render target format YUV420 (0x1).
[h264_vaapi @ 0x4a6e6f40] RC mode: VBR.
[h264_vaapi @ 0x4a6e6f40] RC target: 66% of 6000000 bps over 1000 ms.
[h264_vaapi @ 0x4a6e6f40] RC buffer: 6000000 bits, initial fullness 4500000 bits.
[h264_vaapi @ 0x4a6e6f40] RC framerate: 60/1 (60.00 fps).
[h264_vaapi @ 0x4a6e6f40] Driver does not report any additional prediction constraints.
[h264_vaapi @ 0x4a6e6f40] Using intra, P- and B-frames (supported references: 3 / 1).
[h264_vaapi @ 0x4a6e6f40] All wanted packed headers available (wanted 0xd, found 0x1f).
  Metadata:
    Metadata:
[out#0/null @ 0x4a696bc0] All streams finished
[out#0/null @ 0x4a696bc0] Terminating muxer thread
frame=   60 fps=0.0 q=-0.0 Lsize=N/A time=00:00:00.96 bitrate=N/A speed=4.73x
[AVIOContext @ 0x49e29200] Statistics: 398 bytes written, 0 seeks, 2 writeouts
success in 258ms
h264_vaapi@/dev/dri/renderD129+deint
[AVHWDeviceContext @ 0x1f8f9f80] libva: VA-API version 1.24.0
param: 4, val: 0
[AVHWDeviceContext @ 0x1f8f9f80] libva: va_openDriver() returns 0
[AVHWDeviceContext @ 0x1f8f9f80] Initialised VAAPI connection: version 1.24
[AVHWDeviceContext @ 0x1f8f9f80] VAAPI driver: Intel iHD driver for Intel(R) Gen Graphics - 26.3.2 (1240c65).
[AVHWDeviceContext @ 0x1f8f9f80] Driver not found in known nonstandard list, using standard behaviour.
[Parsed_testsrc_0 @ 0x1f9d4fc0] size:1280x720 rate:60/1 duration:-1.000000 sar:1/1
[auto_scale_0 @ 0x1f92c580] w:iw h:ih flags:'' interl:0
[Parsed_format_1 @ 0x1f9d5280] auto-inserting filter 'auto_scale_0' between the filter 'Parsed_testsrc_0' and the filter 'Parsed_format_1'
[auto_scale_1 @ 0x1f9e4a00] w:iw h:ih flags:'' interl:0
[Parsed_colorspace_2 @ 0x1f9d55c0] auto-inserting filter 'auto_scale_1' between the filter 'Parsed_format_1' and the filter 'Parsed_colorspace_2'
[auto_scale_0 @ 0x1f92c580] w:1280 h:720 fmt:rgb24 sar:1/1 -> w:1280 h:720 fmt:p010le sar:1/1 flags:0x00000004
[auto_scale_1 @ 0x1f9e4a00] w:1280 h:720 fmt:p010le sar:1/1 -> w:1280 h:720 fmt:yuv420p10le sar:1/1 flags:0x00000004
Stream mapping:
[graph 0 input from stream 0:0 @ 0x201c6440] w:1280 h:720 pixfmt:yuv420p10le tb:1/60 fr:60/1 sar:1/1
[auto_scale_0 @ 0x201c4e80] w:iw h:ih flags:'' interl:0
[trim_in_0_0 @ 0x201c6900] auto-inserting filter 'auto_scale_0' between the filter 'graph 0 input from stream 0:0' and the filter 'trim_in_0_0'
[auto_scale_0 @ 0x201c4e80] w:1280 h:720 fmt:yuv420p10le sar:1/1 -> w:1280 h:720 fmt:nv12 sar:1/1 flags:0x00000004
[Parsed_deinterlace_vaapi_2 @ 0x201c5cc0] Picking 4 (MotionCompensated) as default deinterlacing mode.
[h264_vaapi @ 0x201bff40] Using input frames context (format vaapi) with h264_vaapi encoder.
[h264_vaapi @ 0x201bff40] Input surface format is nv12.
[h264_vaapi @ 0x201bff40] Using VAAPI profile VAProfileH264High (7).
[h264_vaapi @ 0x201bff40] Using VAAPI entrypoint VAEntrypointEncSliceLP (8).
[h264_vaapi @ 0x201bff40] Using VAAPI render target format YUV420 (0x1).
[h264_vaapi @ 0x201bff40] RC mode: VBR.
[h264_vaapi @ 0x201bff40] RC target: 66% of 6000000 bps over 1000 ms.
[h264_vaapi @ 0x201bff40] RC buffer: 6000000 bits, initial fullness 4500000 bits.
[h264_vaapi @ 0x201bff40] RC framerate: 60/1 (60.00 fps).
[h264_vaapi @ 0x201bff40] Driver does not report any additional prediction constraints.
[h264_vaapi @ 0x201bff40] Using intra, P- and B-frames (supported references: 3 / 1).
[h264_vaapi @ 0x201bff40] All wanted packed headers available (wanted 0xd, found 0x1f).
  Metadata:
    Metadata:
[out#0/null @ 0x2016fbc0] All streams finished
[out#0/null @ 0x2016fbc0] Terminating muxer thread
[AVIOContext @ 0x1f902200] Statistics: 398 bytes written, 0 seeks, 2 writeouts
success in 344ms
h264_vaapi@/dev/dri/renderD129+deint+tonemap
[AVHWDeviceContext @ 0x16ab3f80] libva: VA-API version 1.24.0
param: 4, val: 0
[AVHWDeviceContext @ 0x16ab3f80] libva: va_openDriver() returns 0
[AVHWDeviceContext @ 0x16ab3f80] Initialised VAAPI connection: version 1.24
[AVHWDeviceContext @ 0x16ab3f80] VAAPI driver: Intel iHD driver for Intel(R) Gen Graphics - 26.3.2 (1240c65).
[AVHWDeviceContext @ 0x16ab3f80] Driver not found in known nonstandard list, using standard behaviour.
[Parsed_testsrc_0 @ 0x16b8efc0] size:1280x720 rate:60/1 duration:-1.000000 sar:1/1
[auto_scale_0 @ 0x16ae6580] w:iw h:ih flags:'' interl:0
[Parsed_format_1 @ 0x16b8f280] auto-inserting filter 'auto_scale_0' between the filter 'Parsed_testsrc_0' and the filter 'Parsed_format_1'
[auto_scale_1 @ 0x16b9ea00] w:iw h:ih flags:'' interl:0
[Parsed_colorspace_2 @ 0x16b8f5c0] auto-inserting filter 'auto_scale_1' between the filter 'Parsed_format_1' and the filter 'Parsed_colorspace_2'
[auto_scale_0 @ 0x16ae6580] w:1280 h:720 fmt:rgb24 sar:1/1 -> w:1280 h:720 fmt:p010le sar:1/1 flags:0x00000004
[auto_scale_1 @ 0x16b9ea00] w:1280 h:720 fmt:p010le sar:1/1 -> w:1280 h:720 fmt:yuv420p10le sar:1/1 flags:0x00000004
Stream mapping:
[graph 0 input from stream 0:0 @ 0x17380380] w:1280 h:720 pixfmt:yuv420p10le tb:1/60 fr:60/1 sar:1/1
[auto_scale_0 @ 0x173813c0] w:iw h:ih flags:'' interl:0
[trim_in_0_0 @ 0x173804c0] auto-inserting filter 'auto_scale_0' between the filter 'graph 0 input from stream 0:0' and the filter 'trim_in_0_0'
[auto_scale_0 @ 0x173813c0] w:1280 h:720 fmt:yuv420p10le sar:1/1 -> w:1280 h:720 fmt:p010le sar:1/1 flags:0x00000004
[Parsed_tonemap_vaapi_1 @ 0x1737fec0] Only support HDR10 as input for vaapi tone-mapping
[Parsed_tonemap_vaapi_1 @ 0x1737fec0] No mastering display data from input
Conversion failed!
exit status 1
Could you run this for us?
for d in /sys/class/drm/card[01] /sys/class/drm/renderD12[89]; do
  echo "$(basename $d) -> $(basename $(readlink -f $d/device))"
done
root@apollo:~# for d in /sys/class/drm/card[01] /sys/class/drm/renderD12[89]; do
done
card0 -> 0000:03:00.0
card1 -> 0000:00:02.0
renderD128 -> 0000:00:02.0
renderD129 -> 0000:03:00.0
root@apollo:~#
I have also ran this for you too:
root@apollo:~# lspci -k | grep -A 3 -E "VGA|3D"
00:02.0 VGA compatible controller: Intel Corporation RocketLake-S GT1 [UHD Graphics 730] (rev 04)
        DeviceName: Onboard - Video
        Subsystem: Gigabyte Technology Co., Ltd Device d000
        Kernel driver in use: i915
03:00.0 VGA compatible controller: Intel Corporation DG2 [Arc A310] (rev 05)
        Subsystem: ASRock Incorporation Device 6007
        Kernel driver in use: xe
        Kernel modules: i915, xe
root@apollo:~#
