I am comparing the video siginal from a ViewTV AT-163 tuner to a HRHomeRun Connect Duo via Channels out to a AppleTV 4 (Non-4K). A MacMini i7 is the server. All connections via the router are either 1000mps (eithernet) or 300mps via WiFi on the Apple TV (verified with speed tests). With my AVR I can switch back and forth between the two sources and the ViewTV AT-163 tuner looks sharper. I mainly see the difference around hard edges of text and network logos, a shimmering. It looks like too much compression is being placed on the video
•Is there any settings I could change on my Mac or AppleTV to get the sharpness equal between the two sources?
Thanks,
Larry
