Is it possible to have channel running in 2 servers at the same time
is it possible to have channel running in 2 servers at the same time under the same account, or would i have to pay for another, assuming it is possible, thanks in advance!
It is possible to run multiple servers at the same time without additional subscriptions but only one of them can use the built in remote access.
If this is what you’re asking. Your question is kind of foggy, can you be more specific in the use case you want.
Yes you can on separate machines or Docker containers but only one will have remote access.
Thank you all for the information
