Currently I have a HDHomeRun and YouTube TVE as sources. It looks like Channels is deduping some stations (FOX only shows OTA or TVE depending on priority) while others like ABC will show both the TVE channel and the OTA channel. I believe this is because there's multiple ABC entries to map to while FOX only has 1.
I would prefer to have both in my guide just in case the OTA signal gets weak and I can quickly change to the TVE stream. I would also like TVE to take priority for recording since I know the signal is consistent and the ~30 second delay doesn't matter on a recording. Is this possible?
