Are they still in business? I think it's been several months now, but I check in on their app from time to time, every channel just buffers forever, then it'll say station is off air. This is during the day.
LocalBtv is working and we have a vlc bridge that runs via docker that you can use to watch it.
You have to remember to map the channels once you get logged in.
The system will have login prompts in the logs when the docker is started.
here is the link.
how can we change the port on these since they are all set for 7777.
All that stuff is over my head. LOL! I'm just curious if they are still in business. Like if you open their app, does it work? For weeks now, I've tried it on the fire tv, nvidia shield, tivo stream 4k... Their app on these devices do not work. And they don't answer any emails.
LocalBTV is online and working.j
I can get channels that are in the los Angeles and they do have some national ones that are available to all.
thanks
Very odd. So I just went to their website and see if I can watch from their site, and I see this message...
"LocalBTV viewers, We're currently experiencing an issue with our main bandwidth provider. The fix is complicated and we are working hard to get it resolved. This impacts some markets in which many channels in the Local tab are temporarily unavailable. The channels in the National tab are still available. Thank you for your patience and hopefully you find some channels you enjoy. Team LocalBTV"
So I guess I'm part of the group effected by this.
Sounds like you might be having an issue in yoru area.
I recently viewed a channel on the system and it worked.
not for me because everything is on port 7777
If you want to watch the docker and you have other dockers running you just change the port.
in the comand it has 777:777. you could do 778:777 and your docker page would be on port 778
I've had it running for months.
Looks like it's still down
I'm not seeing any localbtv on here at all.
Let's hope they can get it back online.
