IS NHKworld TVE working for anyone else(esp verizon?)
I'm just getting this in my logs:
2025/10/01 15:37:21.858377 [ERR] Failed to start stream for ch6769: TVE: Playlist had no segments: https://b-nhkwlive-ojp.nhkworld.jp/hls/live/2003459-b/nhkwlive-ojp-en/index_audio.m3u8
2025/10/01 15:37:21.858470 [HLS] Couldn't generate stream playlist for ch6769-dANY-ip172.30.0.132: TVE: Playlist had no segments: https://b-nhkwlive-ojp.nhkworld.jp/hls/live/2003459-b/nhkwlive-ojp-en/index_audio.m3u8
When I curl that file, the contents have nothing useful for streaming. I feel like this is either the wrong link or someone at NHK has not populated this file properly.
#EXTM3U
#EXT-X-VERSION:4
#EXT-X-TARGETDURATION:7
#EXT-X-MEDIA-SEQUENCE:1
NHKWorld is one of the extra channels that Channels provide so it has nothing to do with your provider
Heres a YT stream tho as backup https://www.youtube.com/watch?v=f0lYkdA-Gtw
You can use that as a backup to view with SLM/PLM
oh, i have it in my TVE source from my provider, I didn't know channels provides it as well, where do I access the channels provided version, or do they slip it into that?
Its already there
The TVE channels 6700–6999 are provided by Channels. They are added regardless of your TVE provider.
The channels 6000–6699 are what your provider authenticates your access to.
As a reply to the OP's original question, I get the same error message using TVE.
Or you could just update prerelease in Channels DVR
Yup, latest prerelease works. :+1:
