Issue: Sorting jumbled
Happens with release 2023.01.23.1746 and beta 2023.02.23.1712
When I go to Virtual Channels, create a channel and click Add Content, the TV Shows and Movies to choose from are not dispayed in alphabetical order. Is this a bug, or something I need to tweak on my end?
@tmm1 @maddox
Sorting order appears to be displaying with the most recently added items at the top of each section (TV and Movies). I see no buttons or options to rearrange display order in this window.
As a side note, if I browse to "http://127.0.0.1:8089/admin/browse/shows", it says the sort order should be Alphabetically, but it's not - it's displaying here as well as most recently added...
Almost 100 views, and not one thought? Am I the only one with this issue?
Add Content dialog window is shown in recently updated order. This is how it's always been.
Looks like a bug then. If you click the drop-down and select Alpha then it works.
This also works: http://127.0.0.1:8089/admin/browse/shows?sort=alpha
Would love there to be options. It definitely makes certain creation (like virtual channels) unnecessarily complicated when the sort order is not alphabetized.
