Issue with Away from Home Streaming M3U
Hello, having an issue with some of my external M3U stream sources. I will get the following on occasion, as well as where the quality dips down and does not recover until I exit out of the channel and back in. I can provide more logs if necessary.
2024/11/17 22:01:50.267472 [HLS] ffmpeg: ch99080-dANY-ip192.168.xxxxx-remux:  [h264 @ 0x12a605410] non-existing SPS 0 referenced in buffering period
2024/11/17 22:01:50.294556 [HLS] ffmpeg: ch99080-dANY-ip192.168.xxxxx-remux:      Last message repeated 1 times
2024/11/17 22:01:50.294584 [HLS] ffmpeg: ch99080-dANY-ip192.168.xxxxx-remux:  [h264 @ 0x12a605410] Increasing reorder buffer to 2
2024/11/17 22:01:50.311473 [HLS] ffmpeg: ch99080-dANY-ip192.168.xxxxx-remux:  [hls @ 0x12a606a70] Timestamps are unset in a packet for stream 1. This is deprecated and will stop working in the future. Fix your code to set the timestamps properly
If possible, can I have it where the custom M3U playlist doesn't share the same stream between 2 devices? I believe that is the default currently. I would consider this the tuner sharing buffer
Most likely it's your source
Probably your source is using adaptive streaming and switching to a lower bitrate/resolution stream.
Try playing the same stream source using VLC player to check.
Channels DVR will consume the source stream, rewrite timestamps and output to small separate buffers for each client (recording engine is also a client). That can't be changed.
I know that it only does it on Apple TV and only outside of the home network. When I am streaming from the host location of the dvr server, it will not do this
So only on the Channels tvOS client connected remotely?
I know there are lots of settings that affect this, so I'll defer to someone who actually uses an Apple TV remotely, or one of the developers.
Had the same issue with the redzone stream from eplus tv. Where the red zone stream will stutter for a second and then go to a lower bitrate. And will not change to a higher bitrate till i close and reopen the stream. And yes, this would be for remote streams
Sounds like adaptive streaming from the Channels DVR Server to the remote client.
Either one of the Developers would have to comment, or you have to submit diagnostics from the remote client and followup with the developers.
I don't use the ATV Client and know there's a lot of Settings involved when remote streaming.
Since this is a User Community Forum, and not an official Tech Support Forum, you should engage the Developers and submit diagnostics, per there instructions.
