Issue with picture / jerkiness
Hi all
I’ve just bought the Channels app, but I’m having a problem with the picture.
The picture and frame rate is perfect, then after 50 seconds or so it will jerk a couple of time. I’ve tried 50hz and 60hz but it’s not made a difference - this happens with both SD and HD channels. I’ve also done a few few reboots.
I’d appreciate any help!! I’m in the UK, using the latest Channels app and latest firmware for the HDHomeRun.
Many thanks, KK
Check the strength of the signal channel by the HDHomeRun Config program.
Are you connected on wifi or wired? Wired gives more stable and reliable connection.
Hi
Signal strength is 93%
Signal quality is 100%
Symbol quality is 100%
I was on wifi but I’ve switched to wired now, connected to a Time Capsule (gigabit).
The picture just seems to struggle sometime with motion, and every so often appears to drop a frame or two. It’s like the picture pauses for a split second. The second continue and the two are never out of sync.
I’ve exactly the same issues :frowning:
The developers helpfully recommended to switch from ‘EPG from DVB’ to any other option.
I can also confirm that this issue has been resolved in the latest Channels Alpha.
Hopefully that helps ya.
KK
Looks good in the latest alpha. Video is not struggeling with motion anymore.
Could you explain this a little more. My picture and audio are fine for the first 10 seconds then after that the two are out of sync by a considerable amount.
