Issue with Port 8089
Hi, have an issue with remote access as I can't get my router setup with port 8089. Having spoken to my ISP, this port is hard wired into the router to allow remote updates of the router's config. It maps my request to a different port. Is there any way you can reconfigure the port on channels to a different port number?
You can configure your router with manual port forwarding and send another port like 8099 to 8089 on your dvr IP.
Then when you auth remotely and see the error saying it can't connect, edit the url and add "&port=8099" to the end.
