Just moved to a new location. Still using same cable card with my HDHR PRIME, but channel lineup has changed. Before I get my DVR server running again, is there a ‘correct’ way to get Channels to see the updates channels list and refresh the guide accordingly? Do I need to remove and re-add my source?
Go to my.hdhomerun.com and find your tuner and have it do a channel scan.
Once you do that you’ll just need to delete the lineup on your HDHomeRun in Channels DVR Server, then ready come the channel mappings. Then add a new lineup to it.
