Kids section
I’ve enabled the kids section in iOS and appletv apps, but nothing appears in the movies section.
I have loads of kids stuff recorded.
How do I get movies to appear here? Some TV shows are included automatically, so it would seem that it should be automatic.
Is this another tag related issue?
You have to manage your library to pick which movies show up where.
Thanks. So it does some stuff automatically, but most require manual input?
And is there any way to do a bulk edit? I kind of like the idea of a kids section but I’m not sure I can be bothered to edit all kid friendly films one by one manually.
When you first turn it on, it asks if you want it to try to auto fill the kids section. If you say yea, it does it’s best by using genres like children and animation. But it’s worth doing a pass yourself to check what it did.
After that you use the visibility feature to choose if your content should show in the kids section, the main library, or both.
There is no bulk editing yet. But using the web admin would work best. It has a way to filter by visibility.
A good strategy is to filter by Kids and open anything that doesn’t belong into a new tab. Then go through each tab to change its setting.
You can do the same while filtered to Library.
Thanks, I found the repopulate kids section which did the trick. Will refine from there. thanks for your help.
