Kodi Add-on
Still not working on ShieldTV ...
2019-10-02 13:32:15.899 T:18398 NOTICE: Creating InputStream
2019-10-02 13:32:16.331 T:18398 NOTICE: AddOnLog: Channels DVR Client: Error starting live stream for ch2.3: open /storage/emulated/0/Android/data/org.xbmc.kodi/files/.kodi/userdata/addon_data/pvr.channelsdvr/channelsdvr-buffer466552069: no such file or directory
2019-10-02 13:32:16.331 T:18398 ERROR: CVideoPlayer::OpenInputStream - error opening [pvr://channels/tv/All channels/pvr.channelsdvr_515.pvr]
2019-10-02 13:32:16.331 T:18398 NOTICE: CVideoPlayer::OnExit()
2019-10-02 13:32:16.365 T:18300 NOTICE: CVideoPlayer::CloseFile()
2019-10-02 13:32:16.366 T:18300 NOTICE: VideoPlayer: waiting for threads to exit
2019-10-02 13:32:16.366 T:18300 NOTICE: VideoPlayer: finished waiting
Can you try toggling the automatically skip commercials setting off and back on (under addons > channels > settings) and see if that fixes live stream?
I toggled auto skip off and on. No live TV on Nvidia Shield.
I'll try the Fire stick later.
Tested this one on my SHIELD:
Oops. I didn't notice new version 2019.10.02.2024.
I installed it and live tv works after toggling, but I'm seeing some pixelization.
I installed 2019.10.02.2219.
I didn't toggle auto skip and live TV worked, but some pixelization.
Working but I am also seeing penalization and pausing ....
Same on Fire TV 4K. Working but pixelization.
I am seeing this error... Recordings play fine no pixelation
m_frames: 1540 m_frameSize: 8 channels: 2
2019-10-02 16:10:56.706 T:23643 NOTICE: Instancing CRendererMediaCodecSurface
2019-10-02 16:10:56.706 T:23643 NOTICE: CRendererMediaCodecSurface::Configure
2019-10-02 16:11:01.173 T:23643 NOTICE: Instancing CRendererMediaCodecSurface
2019-10-02 16:11:01.173 T:23643 NOTICE: CRendererMediaCodecSurface::Configure
2019-10-02 16:13:31.079 T:23649 WARNING: ActiveAE - large audio sync error: -89349.831669
2019-10-02 16:13:31.093 T:23649 WARNING: ActiveAE - large audio sync error: -89332.317919
2019-10-02 16:14:19.465 T:23649 WARNING: ActiveAE - large audio sync error: -89443.267702
2019-10-02 16:14:19.465 T:23649 WARNING: ActiveAE - large audio sync error: -89443.369890
2019-10-02 16:10:56.632 T:23650 NOTICE: Trying to open: samplerate: 48000, channelMask: 12, encoding: 4
2019-10-02 16:10:56.644 T:23650 NOTICE: CAESinkAUDIOTRACK::Initializing with: m_sampleRate: 48000 format: AE_FMT_FLOAT (AE) method: PCM stream-type: PCM-STREAM min_buffer_size: 24640 m_frames: 1540 m_frameSize: 8 channels: 2
2019-10-02 16:15:14.455 T:23809 ERROR: CPVRTimerInfoTag: Invalid client index supplied by client 1099843499 (must be > 0)!
2019-10-02 16:16:02.726 T:23863 NOTICE: CDVDDemuxFFmpeg::Read() stream change
2019-10-02 16:16:02.727 T:23863 NOTICE: Opening stream: 0 source: 256
2019-10-02 16:16:02.728 T:23863 NOTICE: Opening stream: 1 source: 256
2019-10-02 16:16:02.728 T:23863 NOTICE: Finding audio codec for: 86056
2019-10-02 16:16:02.731 T:23863 NOTICE: CDVDAudioCodecFFmpeg::Open() Successful opened audio decoder eac3
2019-10-02 16:16:03.914 T:23864 NOTICE: Creating audio stream (codec id: 86056, channels: 6, sample rate: 48000, no pass-through)
I also see in the View Options panel when in recordings ,,, the recordings count is 0 and you cannot toggle between all and unwatched.
It seems to work if you uncheck Group Items.
Do those work even when Group Items is enabled with other PVR addons?
It works then but I thought that behavior would be the same as in the regular TVShow section where even if grouped it still works...
Also timers are still not working ...
2019-10-02 17:23:59.921 T:25849 ERROR: CreateFromAttributes: Unable to resolve timer type (0x2, 0x2400009, 1099843499)
2019-10-02 17:23:59.921 T:25849 ERROR: CreateFromEpg: Unable to create any epg-based timer type
Does anyone familiar with the Kodi Trakt plugin know why it may not scrobble the Channels DVR recordings? I unchecked all the settings in the plugin that seem relevant (there are some that say not to scrobble from http, Live TV, etc.).
Other than those I am not sure what to do to make it do that. It is one thing that using Kodi would be an advantage for me.
PVR backend needs to supply season/episode meta in order for trakt.tv plugin to scrobble.
We are setting iSeriesNumber/iEpisodeNumber. Is there something else required?
Yep, that's the correct tags, I'm reviewing trakt source and spotted a possible issue. I'll create a PR to address the problem.
::Update::
I am getting a noticeable audio delay when viewing live TV in Kodi, but not when using the Channels app itself. I have your most recent release installed, and have noticed this on both a 4k Fire TV stick and a standard Fire TV stick.
For you Plex Kodi Channels DVR users ... I Put my Channels DVR libraries into Plex ... I then use Plex Connect along with this plugin and Kodi brings it all together. For the skin I use Embuary. I need to be able to use user profiles so Plex fills the void.
PVR Section ....
Info when Viewing ...
Anything I could do to help get it on my main Kodi device (aarch64)? The armhf build for the unofficial HDHomeRun PVR https://forum.silicondust.com/forum/viewtopic.php?f=88&t=71135 works with it.
That's helpful. I'll try to generate some builds using the same compiler next week.
