I am going through some shows and adding labels to their metadata. However, immediately after adding the label to an item, I go back in and check if the label was added to the item and it's not showing the newly added label. However, if I restart the container (Channels DVR is running in a Docker container in UnRaid), and then inspect the item's metadata again, then it's properly showing the label. It may also start showing automatically after some time without restarting the container (I am not sure). Is this expected, or should the label show up immediately? Note that all of these items already had at least one label on them before adding a second (or more) additional new labels.
Updated to the latest pre-release version 2024.10.17.1732 and I am still having the problem.
