Hi folks - I'm wondering if there are any undocumented limits on local library size. I have a large library of local files and it is consistently only scanning files that are in directories starting with A-B and then stopping (in other words, only about 7% of my library is being imported).
Attempting to re-scan the directory doesn't pick anything else up. Deleting the folder, re-adding it and re-scanning it results in the same behavior. No errors in the console, no indication that it's not scanning the full library other than the fact that when I browse TV Shows, the last show alphabetically ends in 'B'.
My only thoughts are a) there is some upper limit on total number of files, and I'm hitting it, or b) there is some video in my library that the scanner silently chokes on.
I'm not really sure how to debug this. Any thoughts? Thanks in advance.
