I think I understand the DRM process. It sounds like there are two sets of keys the decrypt a video stream.
I was playing around and found the url for the stream and license. I found this site to play with DRM streams: https://bitmovin.com/demos/drm
So I plugged in my local PBS information:
DASH format
https://keradt.lls.pbs.org/out/v1/1f291d3c62844ccc940d50328df76f6c/dash-drm.mpd Stream Source
https://proxy.drm.pbs.org/license/widevine/5b1dd955-b7de-41f4-85e6-791e80b78ab0-dash for License
I was able to see my local PBS in the video viewer on the DRM Secure Stream Test page.
If I am able to play PBS through this website, what is missing to make PBS DRM work with Channels? Is it some type of "private/hidden" key that has to be obtained from PBS?
Any light you can shed on the technical workings on DRM is much appreciated.
Thank you in advance.
), but seems that would be possible. I am sure there is something I am missing in my understanding of the subject and any explanation would be appreciated. Could Chromium engine be used to allow DRM to work? Is this more of a copy write concern and thus not done? Thanks again for your explanation.
