Licensing question
How does licensing work? I have 2 HDHomeRun Primes at work that I use to record from like 2 channels. I use OTA and TVE at home to record 99% of what I record. Can I do this? Will it cause issues?
EDIT: I am using Channels DVR, if it wasn't obvious.
You can run multiple DVRs, but only one can have remote access enabled.
Cool. Thanks. I record the items into my OneDrive folder, so they auto download into my preferred media application, and if I need to do any settings, I have certs already on the work PC, and can access it via the URL I have set up.
