Can you repost. I know I saw it before
Thanks. Will the Android app work on a Fire tv
The Android betas are distributed through the Play store, so betas are not officially supported on FireOS devices. If you wish to sideload it yourself, it's up to the user to figure that out.
Ok, I use Apps to Fire tv takes a couple minutes
