Ok, this system has really intrigued me, and I am trying to get up and running.
I have been buying multiple things, to get everything going, but just want to make sure I am clear on everything.
Currently I have a Nvidia Shield set up as my DVR. This isnt going to be permanent, but for now, I just wanted to see how it worked. On my shield, everything is running great. I was able to add Fios, Locast and Hulu TV to the app. And am able to pause, record live TV. I pay for the $80 TV Everywhere.
Now, here is where I get a little confused. I then went to set up my Fire TV 4k stick. And I got a message that an HD Homerun is needed to send my signal to it? Where would I place the HD Homerun in the network? Could it just go anywhere?
Also, which HD Homerun would work. I currently have the HD Homerun Prime, with the cable card slot. I am not going to use a cable card, but could i use this to send the signal to my other rooms in the house? I'll buy whatever I need to , i just want to make sure I am getting the right stuff.
