I am in NYC and connecting remote (TS4K) to my server (QNAP) in PA. Stream stuck so I exited back to guide and then reopened the channel. Since it was also being recorded, I was given the choice between "Live" and "Recording". Picked Live and stream restarted but "Live" was what I just saw 5 minutes earlier. Could not fast forward although I know that we were 5-10 minutes behind the true "Live" timeline.
Are you using original quality? Any chance you had paused at all so that you were a few minutes behind live when the stream froze?
Yes, I was using original quality at the time. No, I hadn't paused the stream, it locked up. I killed the stream and restarted as "Live" but when the "Live" stream started it started 5 minutes BEFORE the point where it had frozen. So I watched that same 5 minutes again in order to watch what was next.
