Loading times from the time you open the app to the time live TV starts playing is significantly slower with the beta. I just did a side by side comparison to confirm.
How much slower?
Do you mean if you leave the app while a channel is playing and return to it?
Or the time to tune into any channel after launching the app?
Time to turn up into a channel after launching the app. It’s easily 3 seconds slower.
Is this happening on all your channels?
I tried a bunch of mine and I don’t see any issues.
If there’s a specific channel causing problems, please capture a sample and send it to [email protected]
For example, if your hdhomerun is 10.0.1.5 and the channel is 500, visit in Chrome http://10.0.1.5:5004/auto/v500?duration=30
Yes, it is happening on all channels, some are a little faster than others.
I will capture the sample and send it over this evening.
Made some improvements in the latest beta; let us know if it helps.
That did help; loading time is noticeably faster.
The latest build this evening has made great strides on load times. Almost indistinguishable with 1.5.3 performance.
I dont think it is slower, see no difference
I use the latest hdhomerun software
This is back to normal with the latest beta. Thanks for reporting the issue.
