I imported several of my media libraries here, great feature, the only issue I have is when I play back it’s not doing 5.1 surround, is this something it can do?
Yes 5.1 is supported for both hdhomerun OTA and local content.
Well is there something I need to change? I definitely am not getting 5.1 on my AVR, when viewing local channels 5.1 works fine.
Which app and platform?
What does View Details show for that import in the web UI ?
Same results on fire tv and Nvidia shield, sorry not sure what you mean on view details on web ui.
Here is what’s in the log
ENC] Starting encoder for Bumblebee_t00.mkv in /storage/emulated/0/Channels dvr/Streaming/file127-ip192.168.1.69-479019535/encoder-65-010268706 at 65 (64.064000) (encoder=h264_mediacodecndk, resolution=1080, deinterlacer=blend, bitrate=10000 segment_size=0.01)
2021/04/29 21:46:31.467410 [HLS] ffmpeg: file127-ip192.168.1.69: [matroska,webm @ 0x2e3c8c4600] Could not find codec parameters for stream 4 (Subtitle: hdmv_pgs_subtitle (pgssub)): unspecified size
2021/04/29 21:46:31.467447 [HLS] ffmpeg: file127-ip192.168.1.69: Consider increasing the value for the 'analyzeduration' and 'probesize' options
2021/04/29 21:46:31.467458 [HLS] ffmpeg: file127-ip192.168.1.69: [matroska,webm @ 0x2e3c8c4600] Could not find codec parameters for stream 5 (Subtitle: hdmv_pgs_subtitle (pgssub)): unspecified size
2021/04/29 21:46:31.467474 [HLS] ffmpeg: file127-ip192.168.1.69: Consider increasing the value for the 'analyzeduration' and 'probesize' options
2021/04/29 21:46:32.179073 [HLS] ffmpeg: file127-ip192.168.1.69: [hls @ 0x2e3c8c5e00] Timestamps are unset in a packet for stream 0. This is deprecated and will stop working in the future. Fix your code to set the timestamps properly
2021/04/29 21:47:35.711499 [DVR] Deleting /storage/emulated/0/Channels dvr/TV/Debris/Debris S01E09 Do You Know Icarus 2021-04-26-2200.mpg
2021/04/29 21:47:40.195757 [ENC] Segment 203 has unexpected duration: inputs=341-342 expected=1.001 actual=1.085 expected_pts=203.203000-204.204000 actual_pts=202.994000-204.037000
2021/04/29 21:48:50.372351 [ENC] Segment 347 has unexpected duration: inputs=629-631 expected=1.001 actual=1.293 expected_pts=347.347000-348.348000 actual_pts=347.097000-348.348000
2021/04/29 21:49:17.108986 [ENC] Stopped encoder for Bumblebee_t00.mkv in /storage/emulated/0/Channels dvr/Streaming/file127-ip192.168.1.69-479019535/encoder-65-010268706 after encoding 65 to 403
You need to set home streaming quality to Original in the app
Home streaming is set to original.
Think I have found the issue, some of my recordings have TrueID 7.1 and 5.1 sound tracks, if it has 7.1 it does not play correctly, if it just has 5.1 it plays fine.
Anyone know away around this? Be nice to be able to select which audio track to use.
You can swipe down in the player and change the audio track
Great that solved the issue, thanks a lot.
Can you submit diagnostics from the app under Settings > Support > Submit Diagnostics > Video Player after playing the video
Okay played some of it and submitted.
