Local_https does not resolve
According to http://DVR_IP:8089/auth
"local_https":"https://192-168-1-12.xxxxxxxxxxxx.u.channelsdvr.net:8089"
The CDVR should be reachable on this url but DNS does not resolve.
Can we fix it?
Doesn't work with some home routers
Wonder if it works for anybody.
If you have nat reflection turned on it will work. on your home network though it would be easier to just go to the local addr
Yep. It is.
