I am trying to run Channels DVR on a Raspberry Pi 4 with two USB drives. I finally got the first drive set up and got Channels running. When I plugged in the second drive I got a bunch of errors. I powered down the system and swapped the USB connections and powered on the system. I got it up and running but now I'm having issues importing from the second drive.
On the second drive I have 3 folders Movies, TV, and Videos. I was able to map to the movies folder but I can't get the TV and Videos to map using Local Content on the settings screen.
On the server it is showing errors
EXT4-fs error (device sdb8): ext4_journal_check_start:83: Detected aborted journal
Ext4-fs (sdb8): Remounting filesystem read-only
If I reboot the system with both drives connected it can't find the image file and load. I removed the second drive and it boots up. Unfortunately when I connect the second drive I get errors.
