I use an OTA Antenna to pull in my local channels. It is the original 30+ year old aerial mounted on my roof, about 20 feet off the ground... and since I live in the flattest part of North America (the Red River Valley on the ND/MN border), I can pull in all the local stations. The antenna works well, especially after (3 summers ago) I replaced all the external coaxial cable going to the antenna with new cables (the old coax was in awful shape and I suspect cracks in the outer cable might have been causing some issues before then).
The current, but intermittent, issue is with my local PBS station where attempts to view one of its "subchannels" (13.2) SOMETIMES cause the video to repeatedly fade to black and back to normal video repeatedly with about a 1 to 2 Hertz rate. It is NOT the same as the breakup of signal when I have a "weak tuner signal". I get no "weak tuner signal", just a flashing video image. Often, the signal is clean, as it happens to be today.
Any ideas from anyone as to possible causes and preferably ways to fix it? In particular, its intermittency is annoying.
