Confirmed. It's fixed!
In Philadelphia location, 6.3 says Stream not available but plays fine through Locast app. Also 12.1 plays but no audio. Running current DVR version on Mac with current OSX version and accessing via current AppleTV Channels app.
When you say "Locast app" are you actually using an app? If so, try via the locast website directly (login and try and view in browser), because the website login/view is the same stream that Channels uses (an App on the other hand, may use a different stream/method of showing the channel).
If, via locast website, you have no issues, then try in Channels again and if still an issue, you'd likely need to submit diagnostics.
You should also update to prerelease, by clicking the dropdown next to Check for Update button.
I updated to prerelease and after the update 6.3 changec to 61.5 and it now works. I did try using Locast via the browser and 12.1 does not work so sent Locast info on the issue. Thanks all for your help.
Locast channel logos for NYC are all missing (except for Channel 13.2 - PBS kids). Running the latest PreRelease.
