I have been using locast with no issues since the beginning. Today, it stopped working, and when i go to a channel it just has the long Get command? What's happening
Please click Support > Submit Diagnostics on the dvr web UI
I just did. It said it was dd3ada25-e305-457d-bcd3-f5d7324e70cb
Where are you located? It appears you're getting errors saying you are not in the United States. If you are outside the US, TVE and Locast will not work for you.
