Disclaimer: Not for the faint of heart or those without some minimal Linux sysadmin experience.
Love my Channels DVR, but the non-managed ever-growing channels-dvr.log always bothered me. Moving it to an alternate volume or using log rotation created problem for the log review feature (and presumably for issue reporting). My workaround is the Linux-only code below that implements a proper logfile fifo. It operates in one of three modes depending on the Linux-version and filesystem being used:
#1- With Linux 3.15+ (almost everyone) and ext4/xfs, uses fallocate / FALLOC_FL_COLLAPSE_RANGE to deallocate the old data from the head of a logfile. This is extremely efficient and there are no extra writes or shifting of data. The file system alters the data block mapping to remove unwanted blocks. When the file reaches its target size, it essentially stays there (+/-64K).
#2- If approach one fails, the code performs rewrite in place. This is far less efficient as each byte of data is essentially written 3-4 times over its lifetime. When the logfile reaches the size limit, approximately 75% of the data is rewritten to the start of the file and the remainder (old duplicate data at that point) is truncated. The file will vary between 75-100% of the target size.
#3- If both approaches fail, no management is performed and the logfile grows unbounded (no different than today). Don't believe approach two would ever realistically fail, but the fallback exists just in case.
Building: gcc logfifo.c -o logfifo
Usage: logfifo [-m size-limit] <output-logfile-name>
(default logfile limit is 10M, minimum limit is 256K)
Installation: modify startup to pipe data though the utility. For my systemd based deployment, I compiled logfifo in the channels data directory and updated the systemd config:
ExecStart=/bin/sh -c 'exec $base/latest/channels-dvr 2>&1 | ./logfifo -m 10000000 $base/data/channels-dvr.log'
Use at your own risk source code below. Though I have been running for several weeks on ext4 (true fifo) and tmpfs (shift-in-place), always possible there is a bug that could cause data loss or worse. (Edited to fix forum suppress of less-than/greater-than in usage.)
// logfifo.c
// requires linux 3.15+ and ext4/xfs for fifo effect
// (for other file systems, does shift within file)
// provided as-is, no restrictions, use at own risk
// to build:
// gcc logfifo.c -o logfifo
// _GNU_SOURCE required for fallocate / FALLOC_FL_COLLAPSE_RANGE
#define _GNU_SOURCE
#include <stdio.h>
#include <stdlib.h>
#include <string.h>
#include <unistd.h>
#include <fcntl.h>
#include <sys/mman.h>
static unsigned int max_size = 10000000;
static unsigned int min_size = 256*1024;
static unsigned int blk_size = 64*1024;
int main(int argc, char *argv[])
if (argc < 2) {
fprintf(stderr, "usage: %s [-m max_size] <logfile>\n", argv[0]);
exit(0);
// max filesize configuration
for (int i = 1; i < argc-1; ++i)
if (strcmp(argv[i], "-m") == 0)
max_size = atoi(argv[++i]);
if (max_size < min_size)
max_size = min_size;
// append to logfile
int fd = open(argv[argc-1], O_RDWR|O_CREAT, 0666);
if (fd < 0) {
fprintf(stderr, "%s: unable to open %s\n", argv[0], argv[argc-1]);
exit(-1);
lseek(fd, 0, SEEK_END);
// buffer each line
char strLine[4096];
while (fgets(strLine, sizeof(strLine), stdin) != NULL)
write(fd, strLine, strlen(strLine));
if (blk_size <= 4096) continue;
unsigned int eof = lseek(fd, 0, SEEK_CUR);
if (eof <= max_size) continue;
// align to block multiple
unsigned int del = eof-max_size;
del -= del % blk_size;
if (del < blk_size) del = blk_size;
// deallocate from front of file to create fifo effect
if (fallocate(fd, FALLOC_FL_COLLAPSE_RANGE, 0, del) == 0) {
// reseek to end just in case (as length has been reduced)
continue;
// fall back to copying newer data to start of file
unsigned char *copy = mmap(NULL, eof, PROT_READ, MAP_PRIVATE, fd, 0);
if (copy != NULL) {
lseek(fd, 0, SEEK_SET);
write(fd, copy+del, eof-del);
ftruncate(fd, eof-del);
munmap(copy, eof);
// recalc large block size for minimum copying
blk_size = max_size/3;
// make it a power-of-2
while (blk_size & (blk_size-1))
blk_size &= blk_size-1;
continue;
// disable further truncation as errors likely to continue
// (unsupported linux version, file-system, blk-size, etc)
perror(argv[0]);
blk_size = 0;
// clean up when source closes pipe
close(fd);
exit(0);
