I have been getting the Connection Lost error quite a bit today. It is happening locally and remote. It looks like a lot is going on in the logs. Thoughts??
[h264_videotoolbox @ 0x7f881980a200] Color range not set for yuv420p. Using MPEG range.
2018/12/20 10:05:13 [HLS] Stopping transcoder session ch1111-dANY-601569c0c120 @ 12m30.826667s
2018/12/20 10:05:13 [TNR] Closed connection to 107673C4 for ch1111
2018/12/20 17:00:12 [TNR] Opened connection to 107673C4 for ch8.1
2018/12/20 17:00:12 [HLS] Starting transcoder for channel 8.1 from 199.83.141.110 (encoder=h264_videotoolbox, resolution=, deinterlacer=blend, bitrate=10000)
[h264_videotoolbox @ 0x7fb470028800] Color range not set for yuv420p. Using MPEG range.
2018/12/20 17:00:33 [HLS] Stopping transcoder session ch8.1-dANY-ae7acda678ab @ 19.285933s
2018/12/20 17:00:33 [TNR] Closed connection to 107673C4 for ch8.1
2018/12/20 17:00:55 [TNR] Opened connection to 107673C4 for ch8.1
2018/12/20 17:00:55 [HLS] Starting transcoder for channel 8.1 from 96.254.123.29 (encoder=h264_videotoolbox, resolution=720, deinterlacer=blend, bitrate=2000)
[h264_videotoolbox @ 0x7fa98882c000] Color range not set for yuv420p. Using MPEG range.
2018/12/20 17:11:33 [DVR] Cancelling stream 107673C4 ch8.1 after 3s read timeout
[mpegts @ 0x7fa987801c00] Dropped corrupted packet (stream = 1)
[mpegts @ 0x7fa987801c00] Dropped corrupted packet (stream = 2)
[mpeg2video @ 0x7fa988800000] ac-tex damaged at 25 52
[mpeg2video @ 0x7fa988800000] Warning MVs not available
2018/12/20 17:11:44 [HLS] Stopping transcoder session ch8.1-dANY-601569c0c120 @ 10m28.4278s
2018/12/20 17:11:44 [TNR] Closed connection to 107673C4 for ch8.1
2018/12/20 17:11:47 [TNR] Opened connection to 107673C4 for ch8.1
2018/12/20 17:11:47 [HLS] Starting transcoder for channel 8.1 from 96.254.123.29 (encoder=h264_videotoolbox, resolution=720, deinterlacer=blend, bitrate=2000)
[h264_videotoolbox @ 0x7fed6302e800] Color range not set for yuv420p. Using MPEG range.
2018/12/20 17:22:26 [DVR] Cancelling stream 107673C4 ch8.1 after 3s read timeout
[mpegts @ 0x7fed63001200] Dropped corrupted packet (stream = 1)
[mpegts @ 0x7fed63001200] Dropped corrupted packet (stream = 2)
overread 14
[mpeg2video @ 0x7fed63028e00] Warning MVs not available
2018/12/20 17:23:53 [HLS] Stopping transcoder session ch8.1-dANY-601569c0c120 @ 10m27.360067s
2018/12/20 17:23:53 [TNR] Closed connection to 107673C4 for ch8.1
2018/12/20 17:23:59 [TNR] Opened connection to 107673C4 for ch1111
2018/12/20 17:23:59 [HLS] Probed live stream in 422.994865ms: h264 1280x720 progressive 3180911bps
2018/12/20 17:23:59 [HLS] Starting transcoder for channel 1111 from 96.254.123.29 (encoder=h264_videotoolbox, resolution=720, deinterlacer=blend, bitrate=2000)
[h264_videotoolbox @ 0x7fde5c03c200] Color range not set for yuv420p. Using MPEG range.
2018/12/20 17:34:12 [DVR] Cancelling stream 107673C4 ch1111 after 3s read timeout
2018/12/20 17:37:36 [HLS] Stopping transcoder session ch1111-dANY-601569c0c120 @ 10m5.702334s
2018/12/20 17:37:36 [TNR] Closed connection to 107673C4 for ch1111
2018/12/20 17:43:27 [TNR] Opened connection to 107673C4 for ch1111
2018/12/20 17:43:28 [HLS] Probed live stream in 428.337901ms: h264 1280x720 progressive 1974748bps
2018/12/20 17:43:28 [HLS] Starting transcoder for channel 1111 from 166.172.184.68 (encoder=h264_videotoolbox, resolution=360, deinterlacer=blend, bitrate=700)
[h264_videotoolbox @ 0x7f874e815a00] Color range not set for yuv420p. Using MPEG range.
2018/12/20 17:46:38 [HLS] Stopping transcoder session ch1111-dANY-2fa0b6f9eb20 @ 3m9.525334s
2018/12/20 17:46:38 [TNR] Closed connection to 107673C4 for ch1111
2018/12/20 17:46:42 [TNR] Opened connection to 107673C4 for ch8.1
2018/12/20 17:46:42 [HLS] Starting transcoder for channel 8.1 from 166.172.184.68 (encoder=h264_videotoolbox, resolution=360, deinterlacer=blend, bitrate=700)
[h264_videotoolbox @ 0x7f9f4782b000] Color range not set for yuv420p. Using MPEG range.
2018/12/20 17:56:56 [DVR] Cancelling stream 107673C4 ch8.1 after 3s read timeout
[mpegts @ 0x7f9f48006400] Dropped corrupted packet (stream = 1)
[mpegts @ 0x7f9f48006400] Dropped corrupted packet (stream = 2)
[mpeg2video @ 0x7f9f47800c00] ac-tex damaged at 35 37
[mpeg2video @ 0x7f9f47800c00] Warning MVs not available
2018/12/20 17:57:54 [HLS] Stopping transcoder session ch8.1-dANY-2fa0b6f9eb20 @ 10m5.137866s
2018/12/20 17:57:54 [TNR] Closed connection to 107673C4 for ch8.1
2018/12/20 18:27:18 [TNR] Opened connection to 107673C4 for ch8.1
2018/12/20 18:38:50 [DVR] Cancelling stream 107673C4 ch8.1 after 3s read timeout
2018/12/20 18:38:53 [TNR] Closed connection to 107673C4 for ch8.1
2018/12/20 18:39:17 [TNR] Opened connection to 107673C4 for ch1121
2018/12/20 18:51:48 [DVR] Cancelling stream 107673C4 ch1121 after 3s read timeout
2018/12/20 18:52:33 [TNR] Closed connection to 107673C4 for ch1121
2018/12/20 18:58:32 [DVR] Skipping job because program already started 1545346790-26 Mad Money
2018/12/20 18:58:32 [DVR] Skipping job because program already started 1545348600-5 NBC Nightly News With Lester Holt
2018/12/20 18:58:32 [DVR] Waiting 12h1m17.153077s until next job 1545393590-22 Today
